What does the image below mean? - Office Equipment & Supplies
    Problem Solver:
,it is a exclamation mark from the English language
Posted on Dec 12, 2014
How to restore sandisk from Factory Image Recovery on Dell Inspiron 1545
Hey Pam,
The factory image on the 1545 is accessed by starting the computer and press the F8 key. Choose the option that reads Repair Your Computer and follow the prompts. If this does not work you will need to manually reinstall Windows. Below is a link that will provide information on manually installing Windows.
How to Restore or Reinstall Windows on your Dell Computer
http://dell.to/Yq0yzy
Dell Factory Image Restore The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu.
This utility formats the operating system hard drive partition prior to restoring the factory image. This means data on that partition is deleted and cannot be recovered.
If the customer creates a second partition with a third-party utility, Dell Factory Image Restore is not affected as long as the image partition is not removed.
If you need any further assistance you can email me from my email address listed below.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email Jesse_Leonard@dell.com
Apr 08, 2013 | Dell Inspiron 15 Laptop
What does the code F40 mean
I know that it can be very frustrating to have issues with your dryer. In the console there are two control boards. One is the machine control and the other is the motor control and the F40 error indicates a communication error. That means the two controls are not talking to each other. There is a test that you can perform to determine what is causing the issue. The image below will provide these instructions for you. Once you have determined this, then you can replace the correct part.
Oct 18, 2012 | Kenmore Elite Oasis ST 6807 Dryer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
The light before the print cartridges is lit up. What does that mean?
I'm not following your very brief non descript description.
But I'll try.
The Print Cartridge lights are at the top of the control panel.
The bottom button is the Rotate Carousel
Now below that is the IMAGING DRUM light
Now if you meant to write "below' instead of before, then we are in business.
If that light is Blinking it means that the drum is empty or missing.
Replace the drum
Jan 20, 2011 | HP LaserJet 2550n Printer
BOTA ERROR CE40
[CE40] Image quality control test pattern abnormality
1.Replace the image quality sensor
2.Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid). MEANING Shutdown the machine,press 0+8,while starting the machine, enter 556 then enter 1,confirm it,then press 557 then 1,confirm it.
Below are further instructions in the same way
3.Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
4.Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to
576)"
That is it
Jan 04, 2011 | Toshiba E-studio 281c Copier
A dash light emblem of a circle with 3 dashes on either side.. what does this mean?
If it looks like the symbol in the image below, it is your brake pad wear sensor.
Your front or rear brake pads are probably worn out (and are below the minimum thickness) and need to be replaced.
Or the wear sensor could be faulty and need replacement also.
Dec 06, 2010 | 1999 BMW Z3
Where to put plug of iP1000 printer
You mean the one that goes into the computer? It goes into the USB port. See the link below for the image
http://www.ladyada.net/images/arduino/usbport.jpg
Dec 04, 2010 | ASUS P5VD2-MX SE Motherboard
It says yahoo id or password incoorect and is i think its been hacked
Reset your password easily by following this link http://edit.yahoo.com/forgot select the option My Password Doesn't Work or I forgot my password as shown in image below..
Image#1
clicking on Next button the page will redirected to below showing page...
Image#2
put your ID correctly in the box and as well as captcha codes as showing in image...
click Next it will ask you information...as below...
Image#3
if your alternate email address is right press Next , it will go for next page like below
Image#4
if your alternate email address is not working follow image 3 2nd option....click next you will be asking for SQ answer...like below...
Image#5
if you put right information here you will be done....
Again if after 2nd image the below window comming contact Yahoo! Customer Care toll free number...
Image#6
For further help please be with us...Good luck
Dec 02, 2009 | Yahoo Mail
Color drivers
Do you mean you do not see color on your monitor display right now?
If so:
1) Find out your monitor model
2) Do a search naming your monitor model (ie) dell 783s) and download the driver specifically for windows 98
3) see below for accessing Device Manager to update the monitor driver:
Microsoft Windows 95, 98, and ME users enter the Windows Device Manager by clicking Start, Settings, Control Panel, System icon, and finally clicking the Device Manager tab.
Below is a basic example of what the Microsoft Window Device Manager may look like when open. Clicking on the below image will open a more readable version of this picture.
Click Image
Dec 21, 2007 | Microsoft Windows 98 for PC
jasbo
jasbo
