DTR-HV250 - 52 STB showing and the it says FULL and then NO SIGNAL. What can I do
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Why
Tried changing the power supply ?
JA
Aug 11, 2014 | Televison & Video
Po705 2001 mustang auto
CODE PO705 IS DTR SENSOR TR SENSOR CIRCUIT MALFUNCTION. POSSIBLE CAUSES, DTR OR TR SENSOR CONNECTOR IS DAMAGED OR SHORTED, DTR OR TR SENSOR SIGNAL CIRCUIT IS OPEN OR SHORTED TO GROUND, DTR OR TR SENSOR SIGNAL CIRCUIT IS SHORTED TO VREF 5V, DTR OR TR SENSOR DAMAGED, PCM HAS FAILED.
Jun 24, 2011 | 2001 Ford Mustang
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
Sep 24, 2009 | Integra DTR-7.1 Receiver
Splitter side of Comcast cable signal unusable. Converter box OK
DTR's are available everywhere. You can also go online and purchase one if your local stores do not have. Also, keep in mind that the splitter you use must comply with the signals unless you use the Video output of DTR.
Jul 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Feb 02, 2008 | Televison & Video
Freeview box (Duraband)
Hi Sandra , it could be poor signal ,worth trying another box on your aerial , also the aerial lead could cause this even the one from the wall plate to the Freeview box ,if your analogue picture is snowy then I would suspect the aerial have you looked for a signal strength meter in the menu , might show how good the signal is
hope this helps
cheers John
Dec 18, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
