Question about Canon PIXMA Office Equipment & Supplies
How do switch to scanner im on copier all time
  • 21 Answers
There should be a scan button on the machine. Some have a wheel that clicks around until you see scan and some have a button. once you see the word scan press either ok or just press depending on your printer. Hope this helps.
Posted on Dec 12, 2014
Hp office jet 6100.
is ther firmware update to it go to www.hp.com suport area download latest drivers ok save to hardrive then remove old ones then install new ones from add remove in control panel ok after new driver hold power in unplug it then plug back in hold that power for 10 sec manaual reset also in the settings
Jan 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hi, I have aproblem with the HP Laser Jet 2840 all in one.. display shows Scanner error 3. i tried several times switching off and on but it does not help. However, each time i switch it on, the scanner...
You are going to have to have it looked at by a trained printer tech.
Just from your description, it sounds like the scanner/copier assembly needs replacing.
Aug 03, 2011 | HP LaserJet 2840 All-In-One Printer
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
Espon stilus dx7450. doesn't switch on, how can
im trying to install my epson printer scanner have no disc can you help
Dec 31, 2009 | Epson Office Equipment & Supplies
Solution for "c30 code on Mita DC 1255
A C30 code is as follows straight from the Tech Manual.
.Timing switch fails to turn ON 2.5
sec after scanner motor starts to
turn in normal direction.
.Home position switch fails to turn
ON 6 sec after scanner motor
starts to reverse.
Solutions:
.Defective scanner motor
.Defective timing switch
.Defective home position
switch
Also check the scanner rail some of the seals on the rail around were the motor sits turn to gunk and will stop the scanner assy from moving.
Jul 01, 2009 | Kyocera Mita FS-C5016N Printer
Dp1820
Im sorry to be the one to tell you but the scanner is network only . you can try network again if you want and go here www.workio.com to get the latest drivers and progs
Oct 31, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
24 people viewed this question
old marine
old marine
