Question about Brother Office Equipment & Supplies
How do I clear a clogged print head on a Brother MFC-990CW?
Restart,Changed cartridge
  • 778 Answers
Hello, Take the print head off. Get a damp not dripping wet paper towel. Dab the print head on the wet paper towel to clean the printhead off and dry with a dry paper towel.
Posted on Dec 11, 2014
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC 425CN will not print black
Have a look at the bk cart. Did you fix it well into position by clipping the support above the cart?
Can you see any difference by ink fuel before and after cleaning cycle? If there is no difference the valve is not open: drill a hole into the top cover and leave it open. Try another cleaning cycle again.
Posted on Nov 05, 2007
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
  • 159 Answers
SOURCE: Have Brother MFC-495CW, and I recently changed
It's not your ink. Error 36 means either the printhead carriage is unable to travel back and forth properly, or it does, but the machine can't get the proper feedback from it. It might be an easy fix, once you get the top cover off the printer section. (Start by prying the narrow covers out of the main cover, then unplug the cables under those covers.) Often it's a small scrap of paper that got into the path of the head. If so, it's probably black with ink and hard to see, but fishing it out with tweezers should fix it.
The machine keeps track of where the head is by counting nearly-microscopic stripes in a quarter-inch strip of film that runs across the printer section. That strip should be oriented vertically and sitting in a slot in the head. If it's stretched up across the top of the head instead of down in the slot, the head can't see the stripes and panics, giving the error 36. Gently lift it and drop it into the slot. If it's smeared with ink, gently clean it with a wet cotton swab.
Posted on Apr 07, 2010
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
How to reset mfc-990 printer
Getting 4F Error message and cannot print on my Brother MFC-990CW
Jun 09, 2012 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Inks are full. Printing has waded out. How do I clean ink cartridges?
hi!
go to ink management and select clean head for all colours
it will take 1 to 4 min
and your printer will work ok
Dec 16, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Ran low on inks on my mfc-990cw and after replacing them now all show full levels but when printing black does not show. ZTried cleaning feature but did not help. Still no black
me too. Brother tech said bad printer head. cost of replacement (only when bad after one year and 3 month) the same value as a new printer.
so, I use it as scanner and telephone. but still not using the printer it comsume all the ink, so it asks you to put new ink in the printer..... waste of $$$$
Will trough it to the garbage!
Nov 13, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
Mar 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
I replaced the black ink cartridge, Innobella, LC61Bk, all correct, for the first time in my MFC-990CW Brother fax, etc.times 3!!!! And I get "white" lines through the text. Yes, I have gone throught the...
i HAVE A lc61 SERIES BROTHER INNOBELLA AND I AM NOT ABLE TO PRINT. wHEN I TEST THE PRINTING I GET ALL COLORS BUT BLACK ON THE TRIAL DEMO I TRIED CLEANING BUT IT STILL DOES NOT WORK WHAT CAN I DO???
Oct 16, 2009 | Brother MFC-990CW COLOR INK-JET MFC Ink...
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
