Question about DeLonghi Ovens
Dear technician, I have just moved into a terraced house with what appears to be a new Delonghi 6 burner free standing cooker. I think it has dual gas. Anyway I turned the oven on and went back around 20 minutes later to find it off. There is no clock and assuming no electric supply to the cooker (house is fine and no trips caused). The oven therefore now does not work because there is no electric supply. I am unable to have a look at the back end (2 heavy to lift with 1 person) Any suggestions? blown fuse? problem with the cooker electrics?
4 Suggested Answers
  • 2651 Answers
SOURCE: small electric kenmore oven
sounds like youve shaken or loosened one of the power leads into the oven, check the circuit breakers first, make sure they have not tripped, if not turn off hte breaker and remove the back panel of the stove youre only getting half power to the unit doesnt sound like anything magor at all
Posted on Apr 30, 2008
  • 3463 Answers
SOURCE: DeLonghi EOF260 tripping the circuit breaker
It is probably an element that is causing the trouble, as it gets hotter, the insulation resistance breaks down, and if there is a weak spot or hot spot it causes the trip to operate.
I'm afraid it is a question of elmination, trying different functions, until you isolate the problem.
Posted on Feb 09, 2010
  • 11896 Answers
SOURCE: Smeg A2 cooker, 11 2years
Is this gas or electric? If it is electric, you will want to test the power to the burners with a voltmeter. This will tell you if the control is bad and not giving power to the burner, or if the burners themselves are bad or possibly just loose or corroded connections.
If you have gas, check the gas valve and the tubing. Make sure there are no holes or gaps letting out the gas, make sure the valves is completely up to allow full gas flow. Also check that the tubing is clean of debris.
Posted on Oct 18, 2010
What do the cooking symbols on my cda oven stand for
Hi ive home and it has a cda cooker installed the only thing is is that the cooker has no symbols on the front so you dont know what settings it is on lol help please
Jul 13, 2012 | Ovens
My son needs a manual for a Jackson Topline cooker, which has an automatic oven, warming drawer. Hw has just moved into a new house and cooker has to be turned off at main switch or it heats up when it...
Had a two Jackson topline cookers for the past 31 years I think the timer is on auto that is why the oven is heating up its self. Look at the clock there will be 3 bottons push in the one that is marked auto that should set the oven back to manual for you. Hope that this helps
Jun 21, 2011 | Ovens
Lost manual
Hi,you can download the manual for your unit for free at; or
Thanks and take care
Apr 19, 2010 | Stoves Premier 720DCa Dual Double Oven
Lost the manual for a new world cooker
To get a new (pdf) manual ask at - they find you every manual.
Jul 31, 2009 | Ovens
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
Apr 01, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Jan 03, 2008 | Ovens
Delongi over nobs
Aug 08, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Ovens Logo
Top DeLonghi Ovens Experts
Jason Harris
Jason Harris
Naftali Haskell
Level 1 Expert
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
