What is motherboard pin assignment in cimpaq presario sr2020nx
  • 35 Answers
I would start by looking at the motherboard and see what motherboard it is. Most manufacturers get their boards from someone like asus or someone. Once you see the motherboard manufacturer, look for a model number, then look up that and you will easily fnd the pinout.
Posted on Dec 16, 2014
3 Suggested Answers
Creative Con
  • 55 Answers
SOURCE: need pin assignment for model: m2n61-ax
If this is a Dell Inspirion 531 here is the owner maual with all the components
http://support.dell.com/support/edocs/systems/inspd531/en/OM/45605A00MR.pdf
Posted on Oct 10, 2009
SOURCE: Hello, I have compaq presario SR2020NX. One
No lights and fans ? then how du u can say that power supply is ok. Is the fan inside the SMPS spinning ? if yes, remove the cpu cab. remove 24 pin power supply cables and 4 pin 12 v supply from the motherboard and re attached them. and try.
Posted on Jan 30, 2010
What is motherboard pin assignment in compaq presario sr2020nx
computer specs are here
http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=c00749174&lc=en&jumpid=reg_r1002_uken_c-001_title_r0001
The motherboard specs which HP give can be found here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&cc=us&lc=en&dlc=en&product=3239113&dlc=en&lang=en
Note that the motherboard is an ASUS A8M2N-LA but that HP have more than one style (corresponding to different component populations of the same board and probably different BIOS's too. pin-outs should be the same though....see joelcoolvette's Fiya pst here
http://www.fixya.com/support/t12362363-front_panel_pinout_connections_asus
18.December.2014
Dec 11, 2014 | Computers & Internet
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
For additional questions please post in a Comment.
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
What is the watt for a power supply for a compaq presario sr2020nx. the computer will not turn on. i checked all other possible power sources.
Looks like it comes with a 550w power supply, so anything in that range would be fine. Below are the specifics if you need them.
Best of luck, William
-------- " Replacement power supply for Compaq Presario SR2020NX- 550 Watt Replacement Power Supply Upgrade
- One (1) 20+4 ATX Power Connection
- Two (2) SATA Connections
- Four (4) large molex connector (4-pin)
- One (1) One (1) floppy connector (4-pin)
- One (1) ATX 12V connector (4-pin)
- One (1) 6-pin PCI-Express Connection (6-pin)
- ATX Form Factor
- 575 Watt Replacement Power Supply
- Input Voltage: 100 - 240 Volts AC
- Width: 5.75"; Height: 3.25"; Depth: 6.0"
- Voltage: +3.3V (38A); +5V (40A); +12V (25A); -5V (0.5A); -12V (0.8A); +5V (2A)
SATA Support
- Supports both 20 and 24 pin motherboard. Great Power Supply Replacement or Upgrade. Compaq PSU Presario SR2020NX Power Supply Replacement"
Mar 03, 2011 | HP Compaq Presario SR2020NX PC Desktop
Hello, I have compaq presario SR2020NX. One morning it was simply dead. No lights, fans. nothing. Power supply and on off sqitch ok. Is motherboard the next check?
Jan 30, 2010 | HP Compaq Presario SR2020NX PC Desktop
Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | HP Compaq Presario SR1420nx...
Computers & Internet Logo
David Payne
David Payne
