Question about Ouellet Wall-Mount Thermostat - Double Pole, Model OTL102F
Thrmostat not clicking on
Nothing
  • Gil Shultz Dec 11, 2014
    Hi mary , We want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2005 gmc savanna van...cooling system will not blow hot heat. water pump,heater core,radaitor and thrmostate replaced. is there any electrical problems/
don't know this van specifically, but some things to check, make sure cabin filter is replaced or clean, you didn't say if the blower itself works, if not, correct or replace. Check the hoses going to the heater core, if hot water is flowing thru the core, both hoses should be hot. Check the heater controls to make sure doors in the system are opening closing as they should, you may just be drawing in cold air and not going thru the heater core.
Feb 11, 2015 | 2005 GMC Savana
12 miles a gallon.. Put on new thrmostat
a few things you can do is replace the fuel filter, air filter, and do a thorough injection cleaning. you can do this simply by buying a can of sea foam from any auto store and turn the car on and pull out a brake booster hose. this is located under the hood in the top right. it should be black, big and circle. also two hoses should come out of it. slowly pour the seafoam in. try your best to keep it running. once it starts bogging down, stop for a second then keep adding. do about a half a can and pour the other half in your fuel tank. turn the car off for about 5-10 minutes and then start it. lots of smoke will come from your tailpipe, but thats okay because that is all that carbon build up. and you should notice more gas mileage!
Jan 01, 2010 | 2000 Chevrolet Blazer
Where is the thermostat?
Thermostat is on the right had side of the engine (passenger side) as you face the engine. It fits in horizontally (below distrubtor). It is difficult to reach.
make sure you buy a thrmostat with a GASKET.
Thanks,
Dec 08, 2009 | 1999 Nissan Quest
KEEPS FREEZING FOOD
This sounds like a thrmostat problem as if it is freezing then all the other components are functioning as they should. This is a common problem and is a relatively cheap and easy repair.
Oct 11, 2009 | Frigidaire Refrigerators
Over heats and engine dies, no thrmostat in system
have the radiator cleaned or replaced and have engine checked if cylinder heads are not causing the over heating
Aug 07, 2009 | 1996 Chrysler Concorde
Refrigeration side of my side by side is freezing
only the thrmostat cost around 80.00rands
May 12, 2009 | Whirlpool Refrigerators
Defrost problem
in my whirlpool refrigirator all liquid items becomes ice even i put in thrmostat at low range plese give solution from rao
Mar 04, 2009 | Refrigerators
Heater not working
try changing the thrmostat, if that doesnt work see if ur heater core is leaking or clogged
Oct 26, 2008 | 2000 Chevrolet Silverado
Ouellet Wall-Mount Thermostat - Double Pole, Model OTL102F Logo
81 people viewed this question
Top Ouellet Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
Are you an Ouellet Heating and Cooling Expert? Answer questions, earn points and help others
