Question about Saws
Where can i find a rip fence assembly for a performax 10" table saw model 90215
The table is 16" with a measurement guide on the front that sits on an angle
Editor925
  • 285 Answers
SOURCE: Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Posted on Jun 03, 2009
  • 251 Answers
SOURCE: i can't get the rip fence on my bosch 4000 table
hi ,
this is the link to the bosch manual for your table saw , it has the assembly instructions ( just reverse them ) and full details of the alignment proceadures required to true the blade/guides and fences up .
http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00160v-1.pdf
hope this helps
Posted on Jan 17, 2010
rowdy45176
  • 2176 Answers
SOURCE: rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Posted on Jul 18, 2010
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
efs_perpends
  • 1996 Answers
SOURCE: I have an older Rockwell 10 in. table saw, model
These lightweight saws can be somewhat problematic in this respect. They have a tendency to come out of adjustment as they are moved about.
First, make sure the blade you're using is true and has little runout. You can check this using a micrometer, or simply marking a tooth and spinning the blade by hand (power unplugged) to see if the blade runs true or wavers in its path. If the blade is warped or bent the problem is probably there rather than the table.
Second, check to make sure the fence is properly adjusted, parallel to the mitre slots. If the fence is out of adjustment, the path of the material relative to the blade will not be parallel, and this can cause poor cuts.
Third, hope it's one of the first two. If not, set a day or weekend aside to work on the saw. Get some good light and flip it over on a table or horses so you can see what you're doing. Have the parts diagram and owner's manual on hand.
You'll need to loosen the bolts that hold the table top against the saw mechanism beneath the top, and shift the saw relative to the top in the desired direction to correct for the out-of true path of the blade relative to the table top. On some lighter saws like yours, this entails re-adjusting most of the saw mechanisms to run true, as they are frequently independently bolted to the underside of the table and not unified construction that moves as a single piece.
You have to shift the saw slightly in the required direction, check the runout of the blade, then repeat until you get it right. If you're skilled and you don't mind standing on your head, you can do this with the saw in position.
There are many excellent articles online that detail this procedure if you search google for "table saw tune up", so I won't elaborate on the details. Try to find one that has a saw similar to yours as an example. Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 29, 2011
Find manual for performax table saw 90215 my fence is broke
I have attached a link to a PDF file of the manual for the Performax.
http://www.menards.com/main/store/20090519001/items/media/Hardware/performax_logo/Install_Instruct/12-0110_240-3600.pdf
On another note, if this does not help you can call:
For questions / comments, technical assistance or repair parts -
Please Call Toll Free at: 1-866-858-2664 (M-F 8am - 6pm)
Dec 25, 2014 | Saws
Sawblade is not parallel with fence on delta tablesaw
The Rip fence SHOULD toe out aprox 0.010mm over the length of the rip fence to prevent binding. Adjust using the Rip fence to measuring rail. Should be adjusters there but if its an old saw, you may have to adjust the measuring rail where it meets the saw frame.
Jan 06, 2014 | Delta Saws
How do i square the table to the fence on a dewalt table saw?
Normally we adjust the rip fence so that it toes out 0.10 mm over the lenghth of the rip fence. Some models have to have the trunion shimmed or the table removed/adjusted to achieve this. The toe out ensures no binding but doesn't effect the measuring. Note. adjusting the trunion is a large job.
Feb 11, 2012 | Dewalt DW744X 10" Portable Table Saw
I have a crftsman table saw mdl # 137228210 I purchased the saw used. I need a rip fence . the guides are allready there. any help would be appreciated
There's an exploded parts drawing and parts list at the link below. This may be useful to see what the fence is supposed to look like. It's not listed as an assembly, just a surprisingly long list of parts that would cost a fortune - if they were all available. Maybe you can find one on ebay. Barring that, you can always just clamp a board to the table to rip with - the hard part is getting the makeshift fence to be parallel to the blade. To do that you can use an adjustable square and measure from a miter slot in the table to get a quick and straight setup. Good luck.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137228210/0247/0744600/P0104056/00001?blt=06&prst=0&shdMod=137228210#Partslist
Feb 09, 2011 | Craftsman 10" Table Saw
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
I can't get the rip fence on my bosch 4000 table saw to square up to the table. the fence is parallel to the blade but when locked down it tilts a hair towards the blade at the top. and it doesn't seem...
hi ,
hope this helps
Jan 17, 2010 | Bosch 4000 - 07 Electric Table Saws
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Jan 12, 2009 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
138 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
