Question about Coleman Electrical Supplies
I have a coleman power 5000 generator and it leaks gas out of the airfilter why?
Just cleaned the carb
  • 23 Answers
Although not 100% sure it sounds as if a gasket around the cylinder might have worn out. I suggest contacting Coleman and ask where to take it for repair,
Posted on Dec 11, 2014
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Hi! I have a Coleman Powermate 5000 maxa er plus. It wouldn't start so I check out the air filter, it was kind of dirty and I found gas in it. I cleaned my carburetor with carb cleaner even if it was clean...
The engine is pulling secondary air from the torn gasket area by the sound of it. It can't govern itself like that.
That must be fixed before any further tests !
Aug 19, 2013 | Coleman Powermate Powermate 5000W...
Serges up and down and stalls after a fes coleman maxa 5000 er plus
Hi mxdidit,
Surging is generally caused by carburetor problems. Squirt some carb cleaner in it and see if that helps it at all. If that helps but does not do a lot, then the carb probably needs to be rebuilt. The carb could also just need some adjusting. Check for fuel leaks around the carb and also be sure the air filter is clean.
Good luck.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 10, 2011 | Coleman Powermate Premium Plus 6250W...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
Is there a gas filter on coleman 5000? runs until hot then shuts off
There is somewhat of a filter inside the tank, however your issue could be air lock or faulty oil sensor. Try running the generator with gas cap loose to allow more air into the tank. If cap is fault try to clean cap vent ports with carb cleaner or just replace the cap. If not fuel lock, remove wire from oil sensor and test again.
Nov 04, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 2500 won't start and gas is leaking out of the
it sounds like mine I think it is the carb is clog up
I am still working on mine
Feb 04, 2009 | Coleman Powermate Proforce 2500 Generator
Electrical Supplies Logo
61 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
