Question about Averatec Computers & Internet
I have an averatec 3200 and I can't configure CMOS setup The computer will not respond to the keyboard Can you give me some information as to what to do to set up CMOS ?
I cannot setup CMOS. The computer does not respond to the keyboard strokes It continually wants to use same commands. Why and what to do?
  • Averatec Master
  • 3,382 Answers
Try a known good keyboard. If that fails load linux in dvd only mode and try that. It will not change your hard drive.
Posted on Dec 11, 2014
I tried changing keyboards,nothing. when I pluged it back in totaly dead, had to plull off jumper, now its running ( fans) that is and performing automatic IDE configuration. [Invalid configuration info...
Many motherboards have a "clear CMOS jumper" capability. There are 3 pins on the Mobo and the jumper is put on pins 1 - 2 for normal operation and moved to position 2 - 3 to clear CMOS memory. (It may be the other way around on some Mobo's). Your PC will oly work with the jumper in the normal position. If you temoraily moved it to the clear position (and then put it back to normal) you erased your cmos memory which remembers the date & time, hard drive cofiguration and many other importnt parameters which need to be set correctly in order for your PC to run properly. If you have the manual that came with your motherboard, it explains how to go into cmos setup and set these parameters. If you do not have this manul, navigate through the menus and choose "default (or optimal) bios settings" Then set your date and time, choose save bios settings and exit bios setup. Hopefuly your computer will start up OK now. If not, you should find a PC technician to help you.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 25, 2011 | Computers & Internet
My dc7100 sff when turned on gives 9 audible beeps that repeat 4 X Then continuously 9 silent beeps over and over Any idea what the issue is?
Here is the solution:
Beeps 9 times:- System not fetching code Microcode
"update" else replace the system board
That deals with your bios.
I would try resetting the CMOS first.
More on fetching code:
http://en.wikipedia.org/wiki/Power-on_self-test
To clear CMOS:
<quote>
Clearing CMOS*
The computer's configuration (CMOS) may occasionally be corrupted. If it is, it is necessary to clear the CMOS
memory using switch SW50.
To clear and reset the configuration, perform the following procedure:
1. Prepare the computer for disassembly.
ã„CAUTION: The power cord must be disconnected from the power source before pushing the Clear CMOS
Button (NOTE: All LEDs on the board should be OFF). Failure to do so may damage the system board
2. Remove the access panel.
3. Press the CMOS button located on the system board and keep it depressed for 5 seconds.
4. Replace the access panel.
5. Turn the computer on and run F10 Computer Setup (Setup-utility) to reconfigure the system.
*When the CMOS button is pushed or the jumper is removed, both the power-on password and the setup password
<end quote>
Your error code page:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00219460/c00219460.pdf
PC homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=402163&lang=en&cc=us
Please rate me if this helps
Andy
May 11, 2011 | Compaq dc7100 Small Form Factor (PJ361UA)...
I have an Averatec 3200 xp home edition. It was a gift. All that came with it was the power cord. How do i reset factory settings?
If laptops do not come with an installation disc, sometimes there is a setting in the BIOS which will allow reseting to factory settings. When the computer is first turned on, it will usually provide a specific key to access the BIOS or setup screen.
Mar 06, 2011 | Averatec 3200 Notebook
Necesito formatear mi maquina es una laptop averatec 3200 solo que cuando quiero entrar al bios tiene password y no puedo quitarlo
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 10, 2010 | Averatec 3200 Notebook
Lost Installing CD cant install to windows XP my computer is averatec 3200 series
here they are , I could not find free cd:
Averatec 3200 XP Windows Driver Recovery CD Restore DiskThis is an automated 3200 XP drivers recovery cd. The 3200 drivers are supplied in a special windows friendly format. This means that your Averatec 3200 XP Laptop will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new windows operating system and half of your Laptop just wont work (with errors like no sound no internet or bad graphics) then this is exactly what this CD has been designed to fix repair. You can also use this CD Disk If you just need to return you.....lots more averatec 3200-series drivers information here.
http://www.user-guides.co.uk/Averatec/AveratecDrivers/Averatec.asp?keywords=Averatec+3200-Series+Drivers&recor=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
Aug 07, 2009 | Averatec Laptop Keyboard for 3200 Series
I need someone to explain to me where I might find the hard reset switch for the bios on my averatec 3200
Open up the inside of the notebook, and you should see a watch style battery. Just remove it while the notebook is turned off and unplugged, and that will reset the BIOS for you.
Apr 14, 2009 | Averatec 3200 Notebook
Suddenly my Averatec won't start
It could be your Power Supply or your CMOS Battery is dead. For Power Supply, you can test by try to connect your Power Cord without battery to see for any PowerPush. If it is still not on then you can check your CMOS Battery for any failure by test the good one from other similar laptop since you had two. I hope this help.
Apr 22, 2007 | Averatec 3200 Notebook
Where is the cmos battery on the Averatec 3200
I can't find step by step instructions for dismantling your laptop (I found them for a Toshiba), but in general the CMOS battery on any PC is on the motherboard (this includes laptop motherboards). You'll have to take the system apart, including taking the keyboard out, etc. etc. to get to it. Take a look at how a Toshiba 6100 is taken apart for an example: http://www.irisvista.com/tech/laptops/Toshiba6100/Toshiba_Satellite_Pro6100_dismantle_1.htm It's not for the faint of heart so I'd recommend taking it to a local repair shop ...
Apr 14, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
