Question about Goodman Manufacturing Goodman ARUF182416 Air Handler, Multi-Position, Direct-Drive,
My Goodman ARUF182416 does not stop running. I have disconnected the thermostat and the blower and heat element stay running until turning off via circuit breaker.
    New Friend:
  • 107 Answers
Most likely your fan and heat sequencer has welded shut. This is such a common problem that when I walked into the Goodman parts supply house; they just reached down below the counter under their computer and handed me the part. They are supposed to open when it reaches the temperature set point or you turn it off. When operating normally they run for a few seconds to a couple of minutes after powering off. They are a bimetal style(KLIXON) that cool off and open the switch shutting down the fan and strips. It is a simple replacement. Shutoff the power and remove wires from the terminals one terminal at a time and transfer to the exact same terminal on the new one.
Posted on Dec 14, 2014
  • Henry Smith
    Henry Smith Dec 14, 2014
    do you have a part number? And where is it located. Thanks.
  • Jim Glover
    Jim Glover Dec 14, 2014
    Just give them the model and serial number. That is what i do to obtain parts to insure the correct part is purchsed. It is located above the blower in the electrical compartment. It will be black with several wires running to it; including the element and fan wires.Basicallly slooks similar to a round part with two sare ends on eac side of the circle.
    Problem Solver:
  • 15 Answers
From what I can gather it seems like a power source error (red wires attached to the transformer) is allowing it to keep running. Another possibility is it could be your speed tap. These are my speculations about what is occurring.
Posted on Dec 11, 2014
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Not hot air
One of three issues
Thermostat not wired properly
failed heat sequencer in air handler
bad heat element in air handler
Feb 10, 2013 | Goodman Manufacturing Goodman ARUF182416...
Fan will not shut off
if you bought the t-stat at menards or any box store change it with one from a contractor they are known for this problem
Dec 13, 2012 | Goodman Manufacturing Goodman ARUF182416...
Ihave a Goodman GUS075-3 model. Turned the heat on for the first time this year. After abt 5 mins. running it started to smell like it was on fire, the breaker shut off. Now,the pilot keeps going out and...
I would suspect that your fan motor burned out. What I would suggest is wait about 1/2 hour with thermostat turned down to lowest setting where it is not trying to turn furnace on. I would then turn thermostat back up to call for heat and see what happens. Most electric motors have a thermal overload on them and if its on motor will not run until it cools back down. Even if this works I would recommend that you have motor replaced and clean blower. Hope this helps. Thanks
Nov 04, 2010 | Goodman Heating & Cooling
Blower does not work and heating element heat with
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Feb 07, 2010 | Goodman GMS90703BXA Heater
Heat will not turn off.Removed thermostat wile
Hello
Could be a stuck control relay,Tsat completes a circut for this relay to engage,once relay contacts are closed heater will start.and stay on until you reach temp.
once temp is reached relay will open and heat will shut down.
By disconnecting all power to heater your forceing relay to open.or simulating a satisfied temp.
I would have a service tech look at your control relay and t stat.
Jan 28, 2010 | Goodman Heating & Cooling
Blower stays on after heat goes off
when the room thermostat is satisfied it stops the heat by stopping power to the sequencer or contactor which is in series with the heating element/s...the TEMPERATURE OPERATED FAN SWITCH then takes over the blower until the heaters cool
Oct 02, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Goodman GMH950904CXAC with white rogers programmable stat. Turn the furnace on and the blower comes on whether there is a call for cool or not. Red led on control board is on, indicating OK. Disconnect...
make sure the blower is not set on rather than auto or the blower will run all the time. You might want to disconnect the thermostat and test the low voltage circuit to make sure the wires are not shorted
Aug 12, 2009 | Heating & Cooling
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
NO HEAT
A blower relay usually has a set of closed contacts that go to the  motor and when the 1st element comes on the power goes on through the sequencer and then these contacts and to the motor heating speed. If you have a blower in AC and with the fan sw to ON u can run the blower on manual 100% of the time until someone can come look at it and the heater coils will cycle on and off with the thermostat. Dont worry about the cost compaird to the elements the motor is nothing and the heat it generates is going into the heated home anyway.
Feb 28, 2009 | Goodman CPLE24-1 Air Conditioner
Goodman Manufacturing Goodman ARUF182416 Air Handler, Multi-Position, Direct-Drive, Logo
94 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
bobalix
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
