Question about GE GTUP270GMWW Laundry : Laundry Centers
Ge Gtup270EMww dryer will not start. washer works just fine
Replaced door switch and start button
  • 4 Answers
If you can hear the motor running, and the drum not turning, it could be the belt. I would check the wall outlet to make sure that you are getting 220 volts, not just 110 volts. After this, the parts are possibilities get more complex and more expense, i.e. circuit board, timer, or motor, and it would probably pay to get a repairman in rather than just trying to change parts.
Posted on Dec 12, 2014
kevin000
  • 1847 Answers
SOURCE: the start button on the
i feel it is loose connection issue,
Posted on Jun 08, 2008
protek480
  • 1714 Answers
SOURCE: GE Dryer GEW9200LW. Panel works, door is closed
You may have a broken belt that connects the drum to the dryer. Watch this video,
Posted on Jul 20, 2009
  • 97 Answers
SOURCE: Dryer will not stay on
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100688
I would believe that you would be looking at diagram location 630 a.k.a. the motor. Many people don't know it but there start switch on the panel has only one function and that is to energize the start switch on the motor.
The only drawback to this is often times manufacturers will not, for some reason or another, sell you the switch but sell you the whole motor instead.
A problem like this could either be in that start switch in the panel making poor contact, or the start switch mounted on the motor (Recently, I was actually able to take one off where it mounts on thedryer motor and open it up in halves and file burned points inside), orwith the centrifugal device in the motor itself. (As cheap and simpleas these plastic start switches on the motor appear, due to perhapsliability or something, often you can not buy that start switch andhave to buy the entire motor with it on it.)
Or your problem may conceivably have a root cause where the dryer drumis in somewhat of a bind due to a drag on it caused by something likegummed up rear roller bearings (not all dryers have these rollers, butsome do), or idler pulley bearing (that is what puts tension on thebelt ). You'd have to open up a dryer access panel (some dryers haveone small panel in rear to get at hooking up the belt, some have alower front panel that pops off), carefully stare at how the belt isfacing and wound around your shaft and idler pulley, or take a pictureor draw a picture, and then after you pull the idler pulley closer tothe motor shaft and slip off the belt, then try to freewheel spin themotor shaft, the idler pulley, and the drum, and see how it feels toyou. If anything feels like it's binding that's probably your culprit.
Posted on Jul 29, 2009
heatman101
  • 43501 Answers
SOURCE: GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 29, 2010
heatman101
  • 43501 Answers
SOURCE: GE dryer has trouble starting.
heatman101
Have ptdn600emwt dryer when pressing start button makes noise but does not run
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Feb 27, 2015 | GE PTDN600EMWT Dryer
I have Hotpoint Ultimate Extra WD72 washer dryer and the start button has stopped working any idea if this is an expensive problem ??
When you close the front washer door, it closes a switch. This switch prevents the washer from operating when the door is open. Your problem is when you close the door, the switch does not go into the closed position. Now when you press the start button, nothing happens. It acts as if the door is in the open position, even though the door is closed. The door switch is defective and needs to be replaced with a new one. Some start buttons only momentarily close and use a relay type of switch to keep power going to the washer. If you have this type of start button, then the relay/switch could be defective. This is a separate part, it is not the start button switch. It is also possible that the start button switch is defective. So up to three parts need to be checked. None of these are expensive repairs.
May 26, 2014 | Washing Machines
Washer does not work but dryer does
Sounds like a safety switch is bad like door switch, or a wire has come off or disconnected somewhere. it will have to be taken apart to fix it. If i can help further just give me a shout.
Mar 29, 2014 | GE Spacemaker GTUP270EMWW
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
Mar 24, 2013 | GE Spacemaker Washer and Dryer Electric...
Dryer won't start in Frigidaire FGX831CS0 stackable. Assumed it was a bad start switch because honey bunny had broken the knob off and was using a pliers to start it but have replaced that and still nada,...
Check the door switch. Turn on dryer as you push in on switch where the door catch is and see if it starts . when closed the pin may not be pushing it in.
Mike
Jun 05, 2017 | Frigidaire FGX831CS Top Load Stacked...
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Dryer stopped working, washer still works
push breaker very hard on off till you hear click then on try again
Aug 31, 2009 | GE Spacemaker Washer and Dryer Electric...
GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Jan 01, 2009 | GE Spacemaker Washer and Dryer Electric...
Washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
GE GTUP270GMWW Laundry : Laundry Centers Logo
85 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
