Question about Electrical Supplies
How to adjust voltage/speed
Frequency is About 63hz and voltage 126+
  • 3,368 Answers
That sounds about right to me. When you add a load the RPM will drop a little taking you as low as about 57hz and maybe 115V. Without being there It sounds like you started it and plugged in your meter.
Posted on Dec 11, 2014
Technic SL5200 turntable speed is to fast on 33/45
1. Some of these turntables were designed to work on multiple voltages. If yours has a voltage adjustment make sure it's set for 110 or 120 V (North American) or whatever your power line voltage is. 2. Does it have a variable speed control with markings around the platter that tell you when it's on speed? if so, make sure you're reading the right scale when you adjust speed. Some Technics turntables have scales for both 50 Hz and 60 Hz (North American) line frequency, with two rows of dots for each, and if you're looking at the wrong scale when you adjust the knobs you'll get the wrong speed. 3. If neither of these solves the problem, you'll have to take it in for service.
Sep 30, 2014 | Technics Audio Players & Recorders
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Why is my honda generator puting out 126 volts?
Is it putting out that voltage with or without load? Speed will influence these units, depending on the model the capacitor regualtor in the back end of the alternator is subject to this error. If you have an AVR then it mayeb adjustable depends on the unti you have. Try measuring engine rpm to be sure it is withing specs first. That is not so high a voltage as it can be 10% of nominal. I am sure it drops down under 1/2 load, then all is ok
Nov 04, 2013 | Electrical Supplies
Voltage Too High
the generator is running too fast..since you are using a manual speed control it means you are overiding the automatic control,, just cut down the speed to where it gives the voltage you wish..or let the auto control work..
Oct 03, 2017 | Porter Cable PorterCable DBSI325 3250 Watt...
Flickering generator on fluroecent lights
The flickering is caused by fluctuating frequency due to engine speed, thes egenerators really are not recommened for powering home systems. It shows up in flourescents when the freq dips around 57HZ and 63HZ
Sep 16, 2012 | Coleman Powermate Premium Plus 6250W...
I want to adjust my 1500watts generator,how will i do it?
What do you want to adjust? The voltage is likely NOT user adjustable. The frequency is controlled by the speed govenor and needs to be checked under load. For engine adjustments search google for small engine repair for tips.
Mar 22, 2010 | Electrical Supplies
Can't find the manual and I'm not sure which power brick is for the scvanner. What is the input voltage?
Output -12V DC /1A , Input - 100VAC or 240VAC, Frequency: 47Hz to 63Hz
Details:
http://www.scanace.com/en/product/1800u.php
Aug 23, 2009 | Pacific Digital PrimeFilm 1800u Film...
Voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
Aug 01, 2009 | Coleman Powermate Powermate 5000W...
PrimeFilm 1800u power
Power Adapter:
Feb 13, 2008 | Pacific Image PrimeFilm 1800u Film Scanner...
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
