Question about The Kitchen Appliances - Others
The heat seal bar does not heat! Can it be fixed? VS106/b
Tried Several times to seal. No heat at all.
  • Gil Shultz Dec 11, 2014
    Hi Jeannie , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Where can I find Teflon tape to cover heat strip on seal-a-meal vacuum system. Model vs106
Firstly, visit their website and look for a spares service. Ordinary Teflon plumbing tape MIGHT do the job but I'm not too sure how you would go about fixing it into place.
Mar 24, 2015 | Kitchen Appliances - Others
How do i fix my whirlpool icemaker it seems that it gets stuck half way into icemaking and does not produce ice.the model is ed5hhaxv002 it is very frustrating i havce tried a blow dryer to heat the r
Your rubber tube is most likely not freezing up and therefore does not need to be heated but only you would know for certain. My experience with ice makes spans several different models but I've found the most common problem for me with no ice being produced is when the bar that shuts of the icemaker gets stuck in the up position because - ice cubes have frozen into a big clump, Ice cubes have jammed the bar by sticking between the ice tray and the bar, or the gear inside that rotates the ice cube tray is stripped in that area because of previous jams and needs to be replaced.
Dec 01, 2014 | Whirlpool Refrigerators
Kenmore# 665.13552k700 has had a constant blinking geen light on normal wash. I have unsuccessfully tried to shut off the power, alternately press normal wah and heated dry several times, held the heated...
Try unplugging or turning off at ciurcut breaker and make sure someone stayas at the dishwasher to be sure the breaker is corredt . the light should go out when breker is turned off then plug back in that will reset the CPU
Jun 28, 2014 | Kenmore Dishwashers
The seal a meal will vaccume but it will not seal. It just keeps running the vaccum process. Do I need to replace my appliance? Or is this a fixable problem
You can fix it yourself for $3 or so if you look for the thermal cutoff (a resister looking device) You can get this at a quality electronics supply. If you just cross the cutoff it will work but could be a fire hazard.
Oct 12, 2013 | Rival Seal-A-Meal VS106 Vacuum Food Sealer
Good Morning, I have a Rival-Seal@Meal Vacuum Sealer Model # VS106/-B....Problem I am having is, it has stoped sealing the bag....Heat strip is not hot at all....Can you help me.....I purchase it just...
I have seen many complaints about those things come to FixYa...It seems that the wire that makes the heat either becomes disconnected or breaks...as far as I can tell there is no fixing or replacement for that.
Wish that I could give you better news.....:-(
heatman101
Sep 20, 2010 | Microwave Ovens
How do I make vac bags out of my roll for my VS106/b
I believe for the Rival machine you cut some of the roll, then seal one end. Put your product in the roll then seal the other end. Generic rolls can be found at http://www.totalvac.com/tiliafoodsaverrolls.html
These will work on a Rival machine.
Jun 14, 2010 | Vacuums
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Bilral
Level 1 Expert
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
