Question about BT Lands Phones
BT 6510incoming calls do not ring at handset when off base why?
  • 3 Answers
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Posted on Feb 14, 2008
SOURCE: No ring on handset
I have no ringing tone (incoming calls) on handset 1 which fits to base station. I have not lost contact with base station hence your remedy is not applicable, all I wish to know is how to get the incoming ring tone back.
Posted on Mar 10, 2008
SOURCE: searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Posted on Aug 28, 2008
SOURCE: BT Studio 3100 handset 1.
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Posted on May 01, 2009
SOURCE: bt graphite handset states out of range but is on base
the manaul states that by resetting the phone should solve this. In my case removing the batteries from the handset for a couple of seconds seemed to work just fine.
Regards
Posted on Jun 07, 2009
Bt 8600 base unit rings additional handsets don't
go into the base unit settings. you can reprogramme it from the menu options
Apr 05, 2018 | BT Lands Phones
I have a bt 86000 twin handset telephone and only one handset can be used to make calls.
if it is on a landline then that will be right as there is only one landline in
if it will not make a call on the other phone when the base phone is on the base then read the instructions a to how to pair that hand piece to the base
Jul 04, 2016 | BT Lands Phones
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Hanged batteries in handset but phone will not ring
Check to see if ringer is set to hi. make sure ringer is turned on. Check to see if the base and the phone are syncronized.
Jan 03, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
My 2nd phone will ring bt the main one I can't seem to turn ringer on..Help Please
If this is the model I think it is, your phone line cord is pluged into the base of the main handset. So let me see if I'm understanding your problem...You have a single line phone with two handsets, and your remote handset rings, but the main handset at the base unit does not. Since your second handset rings when called,your line is working, and your unit's base is working, as well, or the other handset would not ring. Therefore your problem is within the handset itself. I will assume you've made sure the ringer is turned ON and the volume turned UP. Use the Menu button on the handset to find these variables and make sure the ringer is ON and turned UP. Place the handset on the charging cradle. Press the ON button WHILE the phone is on the cradle. You might have to use the speakerphone button to do this. This will resync your handet with its base.
Feb 01, 2011 | Panasonic KX-TG2631 Cordless Phone
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
We have BT Studio 1100 with three handsets. From working well, they all became dead. We have changed the batteries. The phone line is working, and there is electricity reaching all the cradles which...
I have the same phone but with two handsets. Incoming calls only ring on the base and I cannot answer or make calls as the handset is permanently flassing "base 1". I have tried disconnecting and reconnecting. Also tried to restart setup but this is showing unavailable although I can still access the phone menus.
Jul 01, 2008 | Lands Phones
Bt freestyle 210
I have found a free link to the user guide for you on the BT site, it is a very comprehensive guide and there is a BT helpline number if you are still having problems
http://www.shop.bt.com/content/uni2/documentation/4j8p/028609.pdf
Dec 21, 2007 | British Telecom Synergy 2110 Cordless...
No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
124 people viewed this question
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
