Question about Samsung Televison & Video
I am having problems with my Samsung LN32C350D1DXZA. The top half of the screen flickers. I can still see the graphics in all modes.
I've looked at buying the two boards, I just don't know which board I would have to replace or if I could just fix the problem myself.
    Top Expert:
  • Samsung Master
  • 75,581 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Dec 11, 2014
Testimonial: "Samsung BN44-00369D Power Supply for LN32C350D1DXZA (http://assets.shopjimmy.com/media/catalog/product/cache/1/small_image/540x360/f6780bb04c7dec59db3bae8af89107cc/s/j/sjbn9402649k.jpg), will have to be replaced if I cannot find the faulty component/s? It's only $20 so I might just replace the whole board. The other board, Samsung BN94-02649K Main Board for LN32C350D1DXZA (http://assets.shopjimmy.com/media/catalog/product/cache/1/small_image/166x/f6780bb04c7dec59db3bae8af89107cc/s/j/sjbn9402649k.jpg), is the more expensive one ($35)."
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
We have a Samsung LED TV 65 un65f6350af. The bottom half of the screen is dimmer than the top and there is an intermittent flicker on the bottom half as well. Top half looks perfectly normal.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Nov 15, 2015 | Samsung Televison & Video
Problem with setting refresh rate.
Most LCD manufacturer recommend 60Hz, all the LCD monitors (close to 100, 2 monitors per work station) at my office are set to native resolution and @60Hz, LCD refresh rate does not work the same as the old style CRT. You can tell by using the digital camera to see if the screen is flickering or not, point the camera at the CRT monitor and you will see the screen will be rolling but not on hte LCD screen. Try this monitor with other PC.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 13, 2010 | Samsung 943NW Monitor
Upon Start Up my Monitor flickers on for just a second when the blue screen appears, then it goes black. I have to reboot many times before it comes on. I've reset power settings, updated driver for the...
Try it on another PC to narrow down the problem. If does the same on another PC, then you need to open it up and inspect inside the unit, first thing to look for will be capacitors with bulging top/seal or leaking, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 23, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Flicker every 60 sec in Win Media Center TV mode
go to HP.com and look for the TV tuner upgrade. See if that solves your problem. Let me know
Thx
Aug 01, 2009 | Microsoft Windows XP Media Center Edition...
Top half of screen going black.
I've seen this or something similar to this problem on an old lcd screen. The bulb haden't burned out but the system was no longer getting proper 5 volts to the processor chip that processed the image. I ended up desoldering the voltage regulator and soldering a new regulator in it's place it was one with the same amperage so I put a heatsink on it to reduce the chance of another failure.
Feb 16, 2009 | Samsung HP-S5053 Television
Graphics card problem
Shankar,
I looked up your Monitors specefications to try to confirm my theory. Which is that this is a resolution problem. Your Monitor is rated for a maximum resolution of 1024 x 768 at 68 Mhz so this is the max that your Video card can drive this at. However with a CRT Monitor running them at their MAX for extended periods of time can lead to the fuzzyness your talking about. Its likely that when you switched it to the On board or secondary videocard that it defaulted to the standard SVGA display levels of 800 x 600 resolution. Allowing the Video card to increase the refresh rate to 85Mhz.
Which coincidentally is what the Samsung recommends as the optimum setting for this monitor so I believe if you scale down to 800 X 600 @ 85Mhz I think this will clear up your problem. Though if your like me you like to maximize your screen real estate as much as possible.
There are alot of monitors in the market for around $100 USD that have "Native" resolutions of around 1280 X 1024 @ 75Mhz
Hope this helps you
Dave
Nov 17, 2008 | Computers & Internet
hi......
all u need to do is to set up the screen refresh rate to default and always keep ur graphics drivers up to date
Nov 16, 2008 | Nvidia GeForce4 MX 440, (64 MB) Graphic...
Top half of screen is darker than bottom half
The problem is most likley the TV backlight - it is very unlikley to be the graphics card or video input or any other circuitry within the TV.
Also, the problem can be manifested by flashing or flickering of one or both halves of the screen, and sometimes it is a left/right split rather than a top/bottom split, depending on where the lights are positioned. Before failure, you sometimes hear a very high frequency buzz for a few weeks before it fails - the frequency can't be heard by most adults as it ranges from 15kHz-25kHz, but children\animals can usually hear it.
Generally you will need to replace the backlight tube or the invertor that drives it. Generally you can identify the backlights as thin glass tubes buried deep within the panel itself usually with one wire going to each end of them - they are very fragile. The invertor is connected to the backlight tube and looks like a circuit board, often containing a high voltage warning. Usually there are two or four conductors connecting the invertor to the tubes, which can be identified as thicker individual wires as opposed to the flat ribbon wire used for data for the actual image displayed on the screen.
On some screens you may be able to unplug\swap one or both tubes to identify if it's the tube or inverter.
Oct 05, 2008 | Televison & Video
My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Mar 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Open Questions:
Televison & Video Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
