Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: Sound but no image on my LG Plasma TV
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
SOURCE: LG Plasma has sound but no picture
Hi James,
This could be one of two problems. I can't narrow it down any further without having the set in front of me.
1. The plasma panel or the componets which supply electricity to the plasma in the panel have packed up.
2. The video processing unit in the set has gone.
As for the cost of repair, if it's the panel, buy a new TV. It'll be cheaper. If it's the component that supplies the electricity to the plasma on the panel or the video processing unit, expect to pay between 300-400 as a conservative estimate for parts. Labour would be another 100-200.
Hope this helps
