Question about Crafts & Hobbies
When my soon put his pennsylvania flyer train set he unhook the wiring to the fasttrack itself. How to we put in back on the fasttrack?
    New Friend:
  • 161 Answers
Turn the terminal track(where the wires were connected) over,
you should see 2 screws where the wires were attached.
loosen the center rail screw, strip the wire with the red end back - 1/2 inch on the end that was attached to the screw, place wire around the screw & tighten. repeat with the other wire attaching it
to the screw on the outside rail where it was previously attached.
reconnect the terminal track to the rest,connect to your transformer
and play with your train.
Posted on Dec 12, 2014
2 Suggested Answers
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
Car will only go in one direction
please provide more information:
control system used.
locomotive or set number
Jan 29, 2014 | Lionel New York Central Flyer
How to add water
Here's a link to Lionel Service Documents,,Owners Manual for you train.
http://www.lionel.com/media/servicedocuments/71-0018-250.pdf
Dec 02, 2012 | Lionel 6-30018 Pennsylvania Flyer Steam...
Instruction manual
Search the Internet, you may find a PDF file containing the manual. If all else fails, contact Lionel and request a manual.
Dec 08, 2011 | Lionel 'o/o27' 1645 4-4-2 Pennsylvania...
Purchased a Lionel New York Central Flyer Operating Freight Expansion Pack with a coal dumper. My set runs on O-gauge track, not fas track, but the magnet operation appears to be the same. The coal...
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
Apr 22, 2011 | Lionel New York Central Flyer
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Feb 05, 2011 | Lionel Cw 80 Transformer
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
We just got the Hogwarts express and it will not complete 1 loop without derailing or the cars becoming uncoupled.
Well you should probably check the radius of your curves. The Hogwarts Express has a minimum curve of O36 and on a tighter radius curve it will derail. I have found that the Hogwarts train runs better on fasttrack than standard O. You should also make sure the track is flat because if it isn't completely flat it derails. The train isn't designed well so it derails but if you run it slow you shouldn't have a lot of problems.
Dec 27, 2010 | Lionel 7-11020 Harry Potter Hogwarts...
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Crafts & Hobbies Logo
322 people viewed this question
Top Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
