Question about NAD C 275BEE 2Channel Amplifier
I have a NAD 275BEE amp and a NAD375BEE pre-amp running into a Omage 6 Zone speaker switch. I have been running at 3/4's volume or 3:00 o'clock and after a couple of hours it is now kicking out and th
I was thinking of buying another 275BEE amp and bridging them but didn't want the added expense.I was also going to put a fan on it and maybe try a Niles 6 zone switch.
  • Garth Loga
    Garth Loga Dec 12, 2014
    I am going to try a Saga at 350 watts per channel, hopefully it's good quality. It's around the same price and specs of the QSC QX5. Thanks for your help.
  • NAD Master
  • 3,368 Answers
Turn the volume down a tad and you should be ok. I would suggest getting a larger amp, bridging can cause some interesting problems and has an impact on the dampning.
Posted on Dec 11, 2014
  • 1 more comment
  • Garth Loga
    Garth Loga Dec 11, 2014
    What would you suggest?
  • Gil Shultz Dec 12, 2014
    Consider a commerical amplifier such as a QSC. you can get great quality for less bucks and they will run at your power levels. You may need connecting it into your system they are normally balanced inputs. Your combined speakers may have to low resistance for it. It is a very nice unit,
  • Garth Loga
    Thanks for your help, I found a Saga in Canada with similar specs to the QSC QX5 so hopefully it solves the problem and sounds as good as the NAD.
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
My NAD C350 plays very faintly. when I turn the volume dial to the max position, I can bearly hear the music. I can hear properly from earphones output. Thanks
Take care. First put the volume down complete. Then unplug the head phone and than try to raise the volume. Could be the headphone connector does not switch through correct. Could be the connections between the pre and power amp are not in place or not proper pushed in?
Always take care when working with amplifiers. When switching them on with volume to max, you easy can kill your speakers. Also when disconnecting the headphones on full power kan damage the loudspeakers.
Aug 29, 2013 | NAD Audio Players & Recorders
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
Hi, i have a nad c325 bee amp and i have a problem with hooking up speakers. I have just the tiniest amount of sound coming out so there's some signal there. I have tried different speakers so i know its...
Before you continue, turn the volume DOWN. If you can't hear it at mid-volume there's no sense in spinning the volume knob higher. You'll only endanger your ears and speakers if you suddenly resolve the switch or whatever is the problem.
Are all sources acting the same?
Check these things (from the manual):
Tape Monitor selected?
Muting?
Headphones inserted?
Jumpers missing between Pre-Out / Main In?
BTW: the manual is available at retrevo.com
Apr 06, 2010 | NAD C325BEE Amplifier
NAD C320 system sounds like a cheap, tinny tranny
Let's distill this down to its simplist configuration. FM source, stereo.
BTW, a search for NAD 440 only brings up a C440 >>>Tuner<<, no receivers. Are you sure about that model number? The only receiver model numbers with x40 on the NAD website are the C340 and C740, neither of which has a link to a manual (go figure). I have the C740 manual, so I'll use it for a loose reference.
If it still does what you're describing in a basic configuration and the volume control seems to affect it like you belatedly mentioned, I'd suspect a noisy volume control or some other control in the receiver (like a rarely used Tape Monitor switch) that is always there in the circuit but may have oxidized contacts and responds sometimes to burn-through.
Set the volume at a medium setting and repeatedly operate every switch, knob and button (one at a time) to gauge its effects on the sound. You may find one is the culprit. Then it's a matter of accessing it for a shot of contact cleaner.
If you have jumpers between Pre Out and Main In, it might be a good idea to reseat them, too.
Mar 23, 2010 | Audio Players & Recorders
How do you connect power amp to av
I presume you want to use it to drive speakers from a source controlled by the Denon??? Probably the Front channels? We'll assume that's it...
Run RCA cables from the Pre Out jacks to the NAD's L and R inputs. If it has a volume control, set the NAD to its maximum volume (for consistency *), run through the setup for levels and you're done.
* If it doesn't have a volume control it's already set to max. That's normal for power amps. Your receiver / preamp controls the volume fed to them.
BTW: If you're thinking of using two sets of Front channel speakers simultaneously you'll have to choose a level on the NAD that will match up with the others in volume.
Jan 22, 2010 | Denon AVR-3805 Receiver
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Zone 2
if you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Nov 11, 2007 | Onkyo TX-NR801 Receiver
NAD C 275BEE 2Channel Amplifier Logo
115 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
