Question about Northgate STAC2217L (Bundle) PC Desktop
Ethernet and cable modem
I can not get the internet through my ethernet cat 5 port, i can only use usb port, but i can't hook up a wireless router this way. my computer is also a stax2417L model, we tried updating drivers but still not enough to keep connection
  • 121 Answers
Re: Ethernet and cable modem
Try to change the network card to a different pci slot and reconfigure tcp/ip settings
Posted on Nov 12, 2007
0 characters
3 Points
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
Example of a wireless USB device,
Example of an Ethernet adapter card,
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
This is for a Dell Optiplex GX620 Mini-Tower computer,
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
I cannot figure out how to hook up my Belkin Wireless Router. I've tried plugging different cords in different spots and all that jazz and I just can't get it. I got this router from a friend and do not...
First,power down your computer and disconect the power cable to the cable modem.
Install Ethernet cable from the WAN/Internet port to the Cable modem's WAN port.
then install an Ethernet cable from port 1 to your computer. you can use ports1,2,3,4 for different computers.
Then power up the cable modem, then your computer. You should be able to get on the net.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2010 | PC Desktops
I need to connect a D-Link router to my cable modem so that I can use my laptop anywhere in my home
Cable-modem <-- Ethernet cable --> WAN (or "Internet") port on the router
LAN port on router <-- Ethernet cable --> network-port on your laptop
Then, access the "built-in" web-server on the router,
and run the "Wireless Networking Setup" wizard:
* to set an SSID ("network-name")
* an encryption-level (Hint: choose 'wpa')
* a password for your wireless network
Then, disconnect the Ethernet cable from your computer,
and then "wireless available wireless networks".
Select your newly-created network, and connect to it.
Nov 14, 2010 | PC Desktops
Hi,could some one walk me through setting up my Billion modem wirelessly to my Dell Desk top running XP home. I get confused with firewalls,LAN settings etc Ethernet cable is being used at the moment. Do...
I am not familliar with that brand, so I do not know if it is a cable/dsl modem, a router, or a combination of the 2. I will assume it is the cable or dsl modem since you said modem.
The thing we need to do first is give you a basic understanding of whats what, and how it works.
Imagine a 3 tier water fountain. Water flows from the top, to the center, to the bottom.
Your home network is the same way. Signal flows from the MODEM to the ROUTER to the COMPUTER CLIENTS in that order. Keep this in mind. Also, remember you never, NEVER setup a router from a wireless computer client. you ALWAYS use an ethernet connected client in port 1 2 3 or 4.
Quick education about Firewalls: They are programs and devices that are designed SPECIFICALLY to BLOCK TRAFFIC. Think of them like Toll Roads. YOU have to open each virtual port for inbound, outbound, or both. Since that is such a painstaking thing, most firewalls come with default port settings, blocking the most typically unused traffic ports and monitoring the common ones, such as port 80 (the internet port) port 110 (the sending mail POP port) and port 25 (the receiving mail SMTP port). That is why typically, people who can get online (but cant send or receive email) have to disable their firewall or antivirus (security) suite, because the program is closing the ports making them useless. IF you have a router, theres a 99.9% chance that YOU WILL NOT need a firewall. Routers are firewalls by nature.
Quick education about LAN (LAN means Local Area Network, meaning a router inside your house or inside your office or a series of switches and ports setup in your apartment, your "local area") settings: Most lans are DHCP, which means nothing to you, but, in lamens terms it means that you hook it up, turn it on, and it auto configures itself. In the olden days, you had to tell your computer its address, and tell the router its address and the address of each computer, and so forth. Thanks to dhcp, they can now negotiate a lease and assign that info automatically. SO, make sure DHCP is ENABLED. and make sure your lan settings are set to "Obtain ip address and dns server automatically".
Quick education about drivers. you DO need drivers for the wireless devices, you DO need drivers for the ethernet devices, but you DO NOT need drivers for the router, and YOU DO NOT need drivers for the modem. DO NOT HOOK THE MODEM TO THE COMPUTER THRU USB! USB is never to be used unless you do not have ethernet capability, it's like a spare tire. Remove any USB wires from the modem and put them away please! The ONLY wires you want in the modem are POWER and ETHERNET. (they dont make USB routers because USB is not a networking device, USB is a peripheral device)
You will be using Ethernet connection. An ethernet connection requires that you only have the ethernet drivers. So:
YES you need to make sure your ethernet drivers are installed and that your ethernet ports are enabled and working, and:
YES you need to make sure that your wireless card is enabled and functioning, and radio is switched to ON.
Now, remember the fountain? We are going to build it here. The trick is that we have to reset the DHCP list. (if we dont, then it wont work because DHCP will be stubborn and try to talk to the other items, not knowing they were removed). So, we will need to unplug power to the modem and router and shut down each pc client... after you print these directions of course.
While everything is off, hook the main computer into PORT 1 on the router. Make sure that PORTS 2 3 and 4 are empty. (fyi, you can use those for xbox, ps2/3 or wii, or any extra computers). Now, look for a port that says "LAN" or "ETHERNET" or UPLINK on the router. (it will be an ethernet port that doesnt have a number). hook that to the cable/dsl modem. You should now have the modem, hooked to the router, the router hooked to the main pc. Lets start the water flow.
plug power into the modem and wait 1 minute for DHCP synch with the company. (usually you see a sync light or a ready light).
once the modem is synched with the ISp, plug power to the router and wait 1 minute. (so the router can get the dhcp from the modem)
If your modem and router are combined in 1 device, then just wait for synch with isp.
Now start the main computer and try the internet. If you can get online, you have a good network connection. The rest will have to be done by the wireless router mfr, but it isnt hard. In fact, by default, you should be able to start your wireless and get online through it now, but you may want to consider wireless security, (WEP WPA) settings. Call the rtr mfr for those. (its not hard, just tedious and this post is long enough already).. lol. Quick note about wifi: its flaky. If you have a 2.4 ghz phone in your area you may drop connection (wireless only). try different wifi channels to resolve the issue, (call router mfr).
Mar 11, 2009 | Dell PC Desktops
No ethernet port on older Dell desktop
Yes, all you need is a PCI ethernet card. You can pick them up rather cheap. Here is one. You basically plug it into an available PCI port on the inside of your computer. If XP doesn't automatically install it, just insert the included CD with the drivers on it and XP will do the rest. And remember to please give this answer a good rating of fixya. Thanks.
Dec 26, 2008 | Dell Dimension 2400 PC Desktop
How to install a linksys router to my desk top for my wireless laptop
1. plug in the router
2. connect the router to your DSL or Cable Modem using the supplied ethernet cable
3. connect the router to your computers ehternet port with a second piece of ethernet cable
you can use catagory 5 ethernet cable , or catagory 6
Most linksys routers have 4 to 5 ethernet ports to connect computers to.
One of the ports will be marked as the one to connect to your DSL or Cable Modem
Usually when looking at the back of the router the WAN port will be located to the far left.
Thank you for choosing FixYa!
Sep 19, 2008 | PC Desktops
Internet connection problems
Just take out the printer usb cable and put the router usb cale into the usb port and try it . if rob comes again please inform to
May 12, 2008 | Compaq Presario 5000 PC Desktop
Trying to install second linksys wireless router and an error message is coming up
What is the error message?
Also please tell me exactly how you have everything physically setup.
for example
Modem- ethernet cable- router 1 's wan(internet) port- ethernet cable(which port 1-4?)- router 2's wan(internet) port
and if any othe computers are hooked up to it through ethernet cables, please include that.
Apr 17, 2008 | PC Desktops
Internet promplems
for dial up simply a modem .... on laptops if you do not have a builtin modem you can purchase a pc-card modem that goes into your pcmcia slot ... for highspeed either a ethernet (same option as modem) but almost all modern laptops have a built in ethernet ... or usb ... also I highly recommend a router if you are going highspeed ... even if you only have one computer ... a router will protect your system because it provides a NAT firewall. If you go with a router make sure to set up the internet connection on the router do not tunnel through the router with a PPPoE connection
Mar 30, 2008 | PC Desktops
Ethernet card
You either have a bad ethernet port on your modem or pc. If your modem has a USB port, hook that up and run the modem disc to load the driver for USB. You may still be able to get online that way.
Jan 27, 2008 | AMD Compaq Presario SR1030NX Athlon...
Open Questions:
Northgate STAC2217L (Bundle) PC Desktop Logo
60 people viewed this question
Top Northgate PC Desktops Experts
Abhinandan  Patil
Abhinandan Patil
Bob Sloan
Are you a Northgate PC Desktop Expert? Answer questions, earn points and help others
