What does Error u01094 mean?
When sending a fax, an error occurred so I tried again. Same error occurred. Wasn't sure what it meant and tried to find out through searching Google.
  • 25 Answers
Take a look at the trouble error codes list here
Posted on Dec 11, 2014
Fax error code #085
When sending your fax make sure you send it as a black and white doc and not in colour.
L'hit.
Jan 13, 2014 | Canon Office Equipment & Supplies
Faxing problem with HP Office Jet 7130 all-in-one
hi-
chances are you need to change the setting on you hp printer, i mean the fax settings for it and by the way have you tried reseating or unplugging the wire that connects from the wall to your hp office jet? try to unplug and replug it then try sending another fax, update me for any unusualities, thanks!!
May 20, 2008 | HP OfficeJet 7130C All-In-One InkJet...
I can't logiin
Try again later. A system error occurred that wasn't your fault.
Apr 23, 2017 | GPS
Mistake number 421*
According to HP, this error code means that a handshaking (connection) error occurred at some point in the process from the sending fax machine. They suggest to try the fax at a different time when telephone line conditions have improved, or that in some cases the error can occur if the other fax machine is using a fax format incompatible with the HP fax.
Dec 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
1,204 people viewed this question
k24674
