Question about GE Ovens
Have a GE Oven (model # JTP15W0D1WW) that has the first inner window broke on the door - the second inner window is fine. Have found a "window pack" (WB56K20) that replaces the two inner windows and the separator. Question is can I replace just the first inner window with a single piece of glass (WB57K5230) and use the good separator and second inner window?
    Master:
  • 359 Answers
I would replace the whole thing and save the old one for a rainy day.
Posted on Dec 12, 2014
Locked door flashes and oven will not start
Per GE Service bulletin # RA 03-01:
Serial Numbers affected: TZ, VZ, ZZ, AA, DA
Door will not open after self clean cycle due to motorized latch motor stuck in closed position or grinding noise during motorized lock operation.
Both issues are caused by interference of the inner vent trim slot with the latch arm as it travels to the closed position.
Correction:
Replace both the lock motor (WB14T10008) and inner vent trim (WB07T10179).
Failure to replace the inner vent trim will not correct the problem long term, and subsequent lock motor failures will occur.
Jul 27, 2014 | GE Profile JTP18 Electric Single Oven
The inside glass (between the inner and outer glass of the door) of the upper oven door of my GE JT952-30 shattered during a baking cycle. I need the replacement part number and a possible source.
Hello would need the entire model number as you can see by this link there are 32 models of that oven http://www.searspartsdirect.com/partsdirect/part-model/JT952?searchModPar=JT952&pathTaken=modelSearch&prst=0&shdMod=JT952
you can either message me back and I will then pick which is your unit then you would go under door schematic and it would bring up the diagram for your unit which when you clicked on door it would being you to this blown up view of the door this is an example http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Wall-oven-Parts/Model-JT952BF7BB/0432/0125300/G0510389/00005?blt=06&prst=&shdMod= and if you scrolled down to like on this schematic has the outer door glass shown as number 140 in the diagram and then underneath that it would give the part number such as it does for this one being
PART NUMBER: WB57T10259 if you have any further questions or would like me to look your model up further please message me back with the complete model number Thanks Rick
Jun 28, 2011 | GE Profile JT952 Electric Double Oven
WANT TO CHANGE COLOR OF GE PROFILE WALL OVEN..... CAN THIS BE DONE?
I'm in the same situation. I've done a little research and found that the oven door can be changed out rather easily. If you have your Model # and Serial #, located on the inside bottom left corner, you can call GE (1-877-959-8688) and ask if there is a replacement door in the color you would like available for your model. I haven't contacted GE yet, but plan to do so tomorrow to find out if there is a stainless replacement door for my model (and how much it will cost). Hope this helps...good luck!
Nov 10, 2010 | GE Profile JTP18 Electric Single Oven
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
Hello I have a GE Advantium 120 model no. SCA1001KSS 02 man. Jan 08 I caught my coat on the door and broke one of the hooks that is monted on the door, and hooks into slots in the face of the oven....
You can purchase that part directly from GE, go to
www.geappliances.com click on parts and accessories tab, enter your full model number and then follow the menus to the part your after,you will be able to see the cost and order it directly from this site. Good luck!
Nov 24, 2009 | Ovens
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
"Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Jan 20, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
177 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
