Question about DuroMax XP10000E 4-Cycle Gas Powered Portable Generator CARB Compliant
My generator DuroMax XP10000 will not start with the Battery do I need a new battery it will not talke a charge
I had the generator running a long time and then refilled the gas and it still would not start with the key
    Sergeant:
  • 253 Answers
Just try another battery
Posted on Dec 11, 2014
My Duromax XP10000E just started to drop volts to zero intermittently while running.
MMmmm... MANUAL here:
DuroMax XP10000E Generator Owners Manual
(NOTE! SCROLL DOWN at the site above)
A few TROUBLESHOOTING tips here:
http://duromaxgenerators.org/frequently-asked-questions
THIS YOUTUBE may help you too?
DuroMax XP10000E Generator Wiring and Diagram
And finally try this ~ looking at any YOUTUBE that may help you!
Duromax XP10000E YouTube
I hope SOMETHING in the above links helps you, Dan!
Anthony
Apr 16, 2018 | Cars & Trucks
Duromax 10000e generator.no load runs fine on 120v.When volage selector switched to 120/240 engine seems to be under very heavy load,wants to stall and housing on alternator gets very hot.
Hi!
You will need to test the alternator to determine what has failed. We have put together a quick video to show how to do this.
How to test your Electricity Generator AVR Brushes and Alternator on...
All replacement parts can be purchased on this web page: http://www.generatorguru.com/xp10000-xp10000e-xp10000e-ca/
If you are not sure what part you need after running the tests, please come back to us with the results. We are happy to identify the part you need with the results. :)
http://www.generatorguru.com/ask-the-guru/
We are here if you need us!
Dec 01, 2016 | Electrical Supplies
DuroMax XP10000EH Dual Fuel Generator runs well on gasoline, but will only start and run for about 2-3 seconds after priming regulator on LP gas. Changed regulator (new OEM) but same issue remains.
I am sorry to hear you cannot get your Generator started, First I think you should start by looking at the ignition system.
To find the fault please follow these steps:
  1. Removed the spark plug from the engine and re-attach to the Ignition HT Lead. Hold the end of the spark plug tip to a metal section of the engine, and turn over the engine. If all is working correctly, you should see a strong spark, and the engine should run smoothly.
  2. If you do not get a spark, you next need to check oil level is at correctly level (to the very top as if about to flow out) and repeat step 1.
  3. If you still have no spark or it stops running within a few minutes of starting, disconnect the oil sensor wire (you will find it on the front coming from your engine just to the top left of the oil filler cap) and try step 1 again.
  4. Still not getting a spark? Then you need to replace your ignition coil. You can order one from us from our website on this page: http://www.generatorguru.com/xp10000-xp10000e-xp10000e-ca/
If you are getting a spark, but still having trouble starting the Generator, there is most likely a fuel problem too. We can assist you with the next set of fault-finding tests if you need some help. Let us know how it goes. http://www.generatorguru.com/ask-the-guru/
Nov 20, 2016 | Electrical Supplies
Fuel mixing with oil and filling oil tank and cylinder.
the ethanol gas has a way of ruining the rubber tip on the needle valve (in carburetor). When the rubber tip on that valve or the rubber on the Seat go bad, gas can constantly want to fill the carburetor bowl. so much so that it runs into the engine cylinder and past the Rings to the crankcase.
You can replace the needle valve and seat in the carb which is best OR you can put an in-line shutoff on the fuel line and turn it off when you are not using the generator.
Ethanol gas.. very very bad for carburetors.
Sep 05, 2015 | Garden
I have a 4500e duromax starts up and runs then shuts off clean carberator same problem looking for suggestions
On the WEB
manual-duromax-elite-mx4500e-manual ' Generator Nation
www.generatornation.com/tag/manual-duromax-elite-mx4500e-manual/
DuroMax Elite MX4500E 4,500 Watt 7 HP OHV 4-Cycle Gas Powered Portable Generator With Wheel Kit & Electric Start Reviews. By Generator Man Posted in ..
Jul 31, 2015 | Cars & Trucks
Bike won't rev out
Could be electrical.Bikes that have generator systems need battery induced.Unlike an alternator system,like a car you can jump start and the alternator will run with good spark to fire fuel.Generator type need battery induced,so battery must have correct amperage.Can test battery with a volt or/amp test.See what you have with bike not running,then running need about 20% more volts then the 6 or 12 volt battery states (about 14 volts running on a 12 volt battery.Know your battery life span & know that a new battery that year.Plus generator must keep battery charged.I like to have a good spare and also go for a glass mat battery especially if bike is ridden season related. Good Luck!
May 17, 2014 | 2002 Honda CMX 250 Rebel
Electrical power system service required.....ABS warning light, generator warning light, brake failure...car stalled and wont't restart
usually caused by failed generator. Fix the generator and other lights will also extinguish. The car should jump start, but will not stay running without a charged battery. Recommend removing the generator and take to parts store for testing. Would you like instructions for removing generator?
Oct 17, 2010 | 2001 Volvo V70
The bike wont run unless you charge the battery first
Hi!
Take a look on the generator, thats the one charging the battery, the coals in the generator might be needed to be replaced, there are two of them, Also check the two cables from the generator so they arent dameged or broken.
You can take the bike to a repaire shop and ask them to help you measure if the generator gives enough power to charge the battery or on, the can measure the power on the generator and they can measure the power coming to the battery.
Im sure the the problem is the generator or the cables from the generator
Good luck
Nic
Apr 03, 2009 | 1989 Honda CB 1
DuroMax XP10000E 4-Cycle Gas Powered Portable Generator CARB Compliant Logo
254 people viewed this question
Top DuroMax Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a DuroMax Electrical Supply Expert? Answer questions, earn points and help others
