Question about Maytag Dryers
Maytag dryer stops running after 10-15 seconds.
    New Friend:
  • 61 Answers
Sounds like your termal couplin maybe out and detecten that its heating up to much or got a bad stop in the timer if you take the timer start it where you normally do when the machine stops turn the knob past where it stopped and start it again if it does the same thing check and see if you got any heat inside if you do its the timer if not the termal couplen maybe out its a round disk looking on the back side of drum
Posted on Dec 11, 2014
    Sergeant:
  • 253 Answers
Check the exhaust vent in the dryer and the one going outside, sounds like it's plugged. If it's plugged the dryer will get hot real quick and shut off so it doesn't catch fire...
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. ...
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Nov 05, 2012 | Maytag MDE2600 Electric Dryer
Maytag Gas Dryer MDG3000AWW
you check all the wirings maybe you have lost contact wirings!
Oct 09, 2007 | Dryers
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Maytag Neptune dryer beeps a lot and does not run.
what is the model number,sounds like you have a bad computer board but the problem is alot of parts for the neptune are no longer available
Sep 16, 2017 | Maytag Dryers
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
Maytag performa dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Dryer flame shuts off after about 30 seconds
this sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Jan 23, 2009 | Maytag Dryers
Maytag 5806 Gas Dryer starts and suddenly stops.
You may have a problem with a thermal overload sensor. Since it runs and then shuts off, this sounds like the problem.
Dec 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stops running
Sounds like a thermal breakdown in the motor.
Jan 11, 2008 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
109 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
