Question about Autometer 2009 CHEVROLET SILVERADO 2500 HD Auto Meter 7593 Phantom II Gauges
How to fix dash lights gages stop working and start working
Turned on and off key
    Sergeant:
    Champion:
  • 253 Answers
Sounds like just a loose wire somewhere
Posted on Dec 11, 2014
Mazda 6 2005 u0101,u0155,u0121,u0073,u0100 codes coming up
I got the same problem. u ever figure it out? ive cleared codes and there the same. light on cluster lit up . plus some time after pulln away from stop car goes five mph. turn off start up drives fine. im about to burn this thing.
Apr 21, 2013 | 2005 Mazda 6
Took my ford focus to a dealer because key would not turn either way. They said it was the tumbler and would have to be replaced. They jusy called and said they installed new tumbler and reprogramed the...
The reason that the key wouldn't turn must have come from a malfunction of the ignition switch or the connecting rod, rather than the just the tumbler. Since the dash lights & gauges work now, at least part of the ignition switch is working, but apparently not the part that's engaged when the switch is turned to the "start" position.
By replacing just the tumbler, the dealership tech would have jiggled the connecting rod just enough to reseat it (and fix the jam that was causing the key to fail to turn in the tumbler), but didn't fix the real problem, which seems to be a worn out ignition switch or worn connecting/actuating rod.
Here's your steering column anatomy - illustration courtesy Ford Motor Company.
Oct 19, 2011 | Cars & Trucks
I can start my car and all my gages work fine. speedometer,RPM,s ,Fuel, and temp. I can turn on my lights or heater and the gages start jumping all over. The indicator lights and shift indicator lights...
This problem drove me crazy for 2 weeks. Then the car just stopped running. It would turn over but it would not fire. I replaced the crank and camshaft sensors. That did nothing. I replaced the ignition switch and the car started right up. So if your dash indicator lights start doing a light show for you and your gages jump around or just stop working. Try replacing the ignition switch.
Oct 18, 2009 | 1996 Dodge Intrepid
It all started with my signal lights. they would not turn on or blink when engaged. and then the next time they would work. i checked all the fuses and bulbs all are good.. then just the other day my temp...
check the ground from the battery to the battery box make sure the bolt to the box is tight and not broken, If you ever had a battery leak then battery acid could have eaten the wire harness. just look it all over. good luck
Oct 08, 2009 | 2000 Pontiac Sunfire
Fuel Guage problem
Most of the time the gauge unit in the tank goes bad but turning the key on and off won't make any difference. Near the tank there is a multi wire electrical connector, With it unplugged and the key on probing the wires to the front of the truck with a test light one of the wires will light in a slow blinking, This is the gas gauge. with the light blinking the gauge should read something. un plugged should read empty and cross the light to ground it should read full. If the light doesnt come on your on the way back to the dash the wire could be in troble anywhere. repairs for other things are ussally the cause. If the test light check worked then the sending unit in the tank is bad and it will need to be replaced. Repairing them doesn't seem to stay fixed. A gas theif may have run into it with a hose and they can't take much banging around. The fuel gage and fuses are next. The temperture gauge works on the same power if it works OK the power is good. Then its the gage or the wire the is a voltage limiter card in a slot next to the gage in the cluster . The dealer can order a new one when you call them with the VIN and tell them you want the fuel gauge limiter module. If you have the skills to remove the cluster and see the module 1 in. X 2 in. flat electrical card. It has a part # on it and the dealer can verify that your looking at the right part. the gages seldom fail unless their submerised in water. Har driving can sometines loosen the connections to the cluster and redoing them and turning it on again, may correct thr problem. do this with the card and the gage too before you but anything, check the wire from the gage module maks it all the way to the gas tank with a jumper wire and a test light as the wire being broken somethere is most common.
Aug 12, 2009 | 1989 Ford Aerostar Cargo
All dashboard lights out. Car will not start.
i had the same problem,,,all my dash lights were out..speedometer and fuel gage also not working..i found out it was my dash cluster needing to be replaced..it was very expensive to fix so to buy me some time to get the money together my mechanic told me to tap the dash when i have the key on and it worked..my lights came back and it started ..bought me a few mnths to gwt the money together to get it fixed..
Feb 28, 2009 | 2003 Pontiac Sunfire
Starting problem! '99 grand cherokee
The battery seems to be sending the wrong signals. get it replaced.
Feb 06, 2009 | 2005 Jeep Grand Cherokee
The dash gages are not working, fuel gage, speedo, temp gage
Is this the only problem? How did you check the fuses?
Dec 28, 2008 | 1996 Mitsubishi Eclipse
Autometer 2009 CHEVROLET SILVERADO 2500 HD Auto Meter 7593 Phantom II Gauges Logo
85 people viewed this question
Top Autometer Science & Laboratory Experts
William McMath
ray gallant
Are you an Autometer Science and Laboratory Expert? Answer questions, earn points and help others
