Question about DOUBLE POWER TECHNOLOGY Nobis NB09 9" 8 GB Wi-Fi Black Tablet Android 4.1, LCD Touchscreen, 800x480
Having trouble download apps to nobis tablet it keep frozng
    Sergeant:
  • 233 Answers
Does this have an SD card installed? If so it might be corrupted or failing. If not, try a hard shutdown or of you have access to battery area remove battery for a minute then reinstall battery and power tablet back up. One other option would be to go into download and delete any failed downloads and try them again.
Posted on Dec 11, 2014
How do I fix my Nobis tablet when it says insufficient memory when there is no apps on the tablet
Jeffrey, I will post links to hopefully help with your tablets memory issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Out of memory problem when installing from Market
My Nobis tablet is showing insufficient storage when trying to download...
http://forums.androidcentral.com/general-help-how/343882-running-out-storage-space-can-t-transfer-another-partition-sd-card.html
Aug 03, 2016 | Tablets & eReaders
My nobis keeps on going to Androiud is upgrading
If it keeps going to the Store to upgrade but can't ever get anything downloaded, it might be that your internal, SD card, App memory partition has gone bad. Too check its status, touch Settings > Storage and observe the top horizontal bar graph which is your App partition. If it's all one color and says 00.0 bytes then it has gone bad. Your device is pretty much useless should this be the case. The only remedy is to return it for repair.
May 04, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
My nobis tablet is stuck on the nobis start up screen. How do I fix it.
If you Google NobisNB09 stuck on GO you will find many angry people who have the same problem. Rarely does the factory reset procedure work to fix it. IMO they have a problem with faulty internal SD chips. So, what I'm saying is you may not be able to fix the problem other than trying to get an RMA and sending it back for repair if it's still in the warranty period.
Here is the factory reset procedure.
1) press and hold at the same time both the power button and the volume(-) button.
2) keep holding them until you see the Nobis screen, Then it will go off. Keep on holding both buttons down for perhaps ten or fifteen more seconds and finally you will see a screen with some green text options
3) Among the options is one that says something like "wipe data/factory reset.
4) Using the volume (+) button scroll to it and then press the power button once to select it.
5) Another screen will come up with text options of no, no no for five or six lines with one that has a go ahead for the reset option. Again, using the volume (+) to scroll to the reset option and select it using one push of the power button.
6) you will get a reboot option.
7) reboot by pushing the power button, it will turn off.
8) Give it a minute or so and then push the start button and
hold it until you see the Nobis screen. Let it go and wait. If the hardware's OK it will go through the initialization routine which
should take several minutes. Anything more than about ten
minutes without going to the set up screen indicates you have
bad hardware such as a faulty internal SD memory.
One hint: turn off your wi-fi router so it can't connect to wi-fi.
It will boot up with the wi-fi ON and it will connect to any open
router it can find and commence to download updates for all the apps. This makes it take forever and can completely fill
up the available app partition memory and result in another failure to boot up next time.
IMO the Nobis NBOP is a POS! I have one so I know.
Apr 06, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Tried to download some apps on my digiland 701Q tablet I'm told I'm not able to accept downloads .
Your memory for apps might be full. Go to Settings > Storage and look at the top bar graph. If it says it's full then there's your problem. You'll have to delete some apps or clear data and cache on some in order to get some room freed up. You might be able to move some of the apps to an external SD card if you've put one in the slot if you have a slot.
Or, if the top bar graph says 00 bytes of memory then your
app partition got trashed somehow - probably a faulty internal SD memory. I have this problem on a Nobis NB09 and so have a lot of other folks when I Googled Nobis stuck on Go and NobisNB09 won't boot up etc. Nobis fixed it once but it lasted only two or three weeks and now they won't issue me another RMA number. I would advise everybody to not purchase Nobis - now run by Bidwell products as they don't seem willing to honor warranty.
Mar 28, 2015 | Tablets & eReaders
Nobis 10 inch tablet , will not turn on
Greetings sandra
Here is a link I used to reset a Nobis tablet last month and it worked. Good luck
Chadman
https://youtu.be/x6u2qWWeaEM Android tablet pc hard reset reboot
Mar 25, 2015 | Tablets & eReaders
Why won't my tablet download apps off the play store?
Your internal memory app partition is gone. The Nobis NBO9 has some serious issues with bad internal memory storage. Yours is undoubtedly unable to download anything from the Store because the operating system *sees* no place to download them to.
Go to Settings > Storage and examine the top horizontal bar graph. It will probably be all one color and the text under it will probably say 00.0 bytes of storage. This means bad internal memory.
You are stuck with a broken tablet unless you can manage to get Nobis, now Bidwell to issue an RMA. Good luck with that as they don't seem to eager to stand behind their defective product.
Feb 27, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Nobis tablet has 5 gig space left, when trying to download new apps, message pops us saying there is insufficient space on device
you will need to reduce space, delete unwanted files items and create space for new apps, alternately see if you have a microsd card (external storage) which is not full.
Feb 26, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
IT TELLS ME THERE IS NOT ENOUGH SPACE TO ADD GAMES AND NOT THAT MANY ON IT
1) download an app called Clear Master
2) Clear all Junk and make space
3 Move to the ext memory the apps that are space intensive
Enjoy
Dec 26, 2014 | Tablets & eReaders
How to download gAMES AT PLAY STORE KEEP SAYING ERROR NO MEMORY BUT I HAVE SPACE ON THE Tablet
The Nobis NB09 Tablet simply has too little space partitioned for apps. It has only about 660 MB available. Just downloading and installing the updates for the native apps from the Store will result in the partition being filled to about 550 MB. This leaves only about 100 MB left for apps you want to add.
Click on *Settings* then click on *Storage* The top bar graph is your app partition. It will probably show as about 660 MB and the green bar is how full it is. It wouldn't surprise me if your green bar was at or near the right hand side meaning a full tank.
The second bar graph is your total built-in SD card memory. It's supposed to be 8 GB but it's shows about 5.5 GB. It looks like a lot of empty space but none of this can be used to download apps. From time to time to time there will be an app you run across that will be able to install on the external microSD card you can push into the slot on the back. And one or two of the native apps might be able to be moved to this external microSD card. But, you STILL have too little room to add extra apps.
Nobis simply didn't allocate enough space for app installation and you are stuck with the native apps plus maybe three large or six to eight smaller apps before the internal app space is FULL.
Just feel lucky that what little app memory you have still works. Mine went bad after less than two months and it remembers NOTHING. Every time I turn it off it boots into the set-up mode and retains no changes I made prior. It will not download a thing from the store because the app partition reads in the bar graph 0.00B available. IOW, bad memory. I am currently trying to get a response from the Midland website that took over Nobis and they claim they will reply within 48 hours. It's been two days and no reply so far. There is a phone number listed to call for a RMA (return merchandise authorization) I might have call it if they don't reply to the email.
Basically the NobisNBO9 is junk. Do a little Googling and many many people have problems such as it not booting up - I feel this is all to do with memory gone bad. Cheap Chinese memory - not reliable enough to last more than a month or two.
Oct 05, 2014 | DOUBLE POWER TECHNOLOGY Nobis NB09BLUE 9"...
DOUBLE POWER TECHNOLOGY Nobis NB09 9" 8 GB Wi-Fi Black Tablet Android 4.1, LCD Touchscreen, 800x480 Logo
146 people viewed this question
Top DOUBLE POWER TECHNOLOGY Tablets & eReaders Experts
ka4iup
ka4iup
ray gallant
Tom Chichester
Are you a DOUBLE POWER TECHNOLOGY Tablet and eReader Expert? Answer questions, earn points and help others
