Question about Vista-Pro Automotive 1997 - 2000 Dodge Avenger HVAC Heater Core W0133
How to diagnose crank but won't start. Has injector pulse but no spark.
I have replaced distributor cap and rotor
    Master:
  • 373 Answers
If it has no spark, then look at the coil. It may need to be replaced.
Posted on Dec 11, 2014
What shall I do my car running normally but suddenly the engine stop running and never start again.
need more info, year,make,model, is the engine light on have you retrieved all engine codes, when turning engine over, is it spinning very freely or just like it always did,
RE POST with all this info. to get a better diagnoses
Problem 5 Engine Cranks But won Start
http://www.linnbenton.edu/auto/perform/no_start.html
Engine cranks but won start
Feb 05, 2016 | Cars & Trucks
1984 jetta 2.0
Does tjhe rotor is correcty line up? Does the distributor is line up to? If you got fuel, mybe the spark isn't done a the proper time. Take of the distributor, the rotor shoulb be line up with a mark on the distributor imself. and the cap shoulb be line up with this mark to.
You can also check this link http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280053186
Hope that helps.........
Jul 20, 2008 | 1984 Volkswagen Jetta
I have a 2000 gmc Sierra 3/4 ton 4x4 k series I have no spark to my spark plugs I have changed the crank sensor an the ignition module not sure what else I can try I'm thinking maybe the ignition coil
Check to see if you are getting spark from the coil to the distributor. I suppose the engine is a 5.7 liter?If not getting spark to the cap, then check for power and ground pulse at the coil.If there is spark at the cap, replace the ignition rotor. If there is no power or ground pulse at the coil,check to see if the ignition rotor is spinning when the starter is engaged. If the distributor is not spinning while cranking the engine there are several more things you'll need to check,i.e.,distributor gear and pin as well as oil pump if the pin or gear are damaged.
Mar 05, 2015 | GMC Cars & Trucks
No spark wont start
The coil in the distributor is THE coil. Try replacing that coil.
Jul 28, 2014 | 1995 Ford Aspire
98 crv won't start
Check compression and timing belt. If belt is ok and you have compression, check to see if you have a pulse at the injectors. You use a device called a NOID light (basically a light bulb that plugs into the injector plug. Unplug the injectors one by one and plug the light in then crank the engine. Light should blink on and off if the system is working properly. If not check for a bad crank sensor, blown injector fuse and wiring harness. Hope this helps.
Nov 02, 2011 | 1998 Honda CR-V
1990 Nissan Stanz. We just purchased this car for our son as a first car (bought it at an aution) The car is getting oil pressure and fuel to the engine. Problem it turns over but will not start. We tested...
you should chek ur actual injector pulse to see if fuel is gettn injected into ur engine. one way to see if its a fuel problem is to try shootrin carb cleaner into ur throttle body or a vacuum hose directly on the intake manifold while cranking engine an even see if it try to start. if it pops over an trys to start then ur spark is obviously good enough,an ur not gettn injector pulse. all ur injectors should have 12volts and only the ground gets pulsed on and off to open an close injectors,while someone is crankin engine.thats wen voltaged needs checked. if it trys to start then i woul def check ur cam sensor which controls injectr pulse ,most likely located in ur distributor.also good idea to chek all ur fuses,and even try to see if there are any codes in ur computer system,which their probably are. very important wen diagnosing a no start condition. good luck coutybgg
May 01, 2011 | 1990 Nissan Stanza
It will crank, but wont start. spark plugs are not firing
Most of the time,on that model,it is the distributor,if the timing belt has not broken,pull the distributor cap,and turn the engine over to see if the rotor button is turning,if it is not,then the timing belt has broke.if the rotor button turns,replace the distributor.
May 09, 2010 | 1992 Honda Accord
I have a 85 blazer with a "w" vin number that won"t start and isn't receiving any spark or fuel. I know it isnt receiving spark and have been told that it could be a cam sensor or crank sensor that would...
most of the time the module will fix it. it's cheap and easy to replace.
just remove the distributor cap and the rotor and you will see it.
however, according to your info, the blazer does not have a vin code W in 1985. that's a 7.4 liters engine, the full size blazer only have 5.7 liters
Mar 05, 2010 | 1995 Chevrolet Blazer
I have a 1996 GMC yukon with 5.7 engine it is not firing I have changed the coil this did not fix problem what do I check next
Check for injector pulse if no pulse with no spark check ignition module in distributor or crank sensor.
Nov 11, 2009 | 1996 GMC Yukon
Vista-Pro Automotive 1997 - 2000 Dodge Avenger HVAC Heater Core W0133 Logo
51 people viewed this question
Top Vista-Pro Automotive GPS Experts
Are you a Vista-Pro Automotive GPS Expert? Answer questions, earn points and help others
