My son drove a toy car on our mitsubishi projection tv. Now the whole bottom of the TV is very dark. Any way to fix this?
  • 3,368 Answers
He probably damaged the screen, sorry!
Posted on Dec 11, 2014
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
Mitsubishi rear projection tv is too dark to see picture
This is a very common problem within your projection TV set there is a small red, green, and blue picture tube. On top of the tube there is a lens that focuses the video on the screen. Between the lens and the top of the tube there is a hollow chamber filled with a clear liquid. This fluid is specifically designed to keep the tube from overheating. After about 4-5 years the fluid will start to become cloudy and will will get worse over time. Tvrepairkits.com is a good place to get a repair kit to fix this condition yourself.
Dec 19, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How do I reset tv it's dark and now it wont turn on its a mitsubishi DLP tv
Good day!!!
That problem is not fixed by resetting of unit..
That problem is usually cause of faulty light engine..Try to replace it with the part # (part number usually indicated on the engine itself printed in sticker)..
Hope it helps..
Dec 14, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Dark pic on screen, unable to correct with regular means.
Regardless, my answer stands. It needs repair by a qualified technician. Rates vary by area. Make telephone inquires.
Jan 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture getting dark on my 70" mitsubishi projection
Good Day;
It sounds like your lamp is getting weak, replace lamp. Good Luck, big IRISH.
Oct 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
