Question about Belling Ovens
I have a belling cook master. It is all gas. The gas fan oven is working but not getting very hot. Any thought please?
  • Belling Master
  • 3,382 Answers
Have your gas pressure checked.
Posted on Dec 11, 2014
Testimonial: "Thank you. But the pressure is ok on the other parts."
I replaced the element in my belling double oven, it wored for a while but was very hot thought it was the thermostat, now it has no heat at all no light but the fan still works.The top oven and gril has...
Hi.
Replace the temperature probe located in the oven cavity. The probe was initially shorted. That caused temperature runaway with the oven getting too hot. After a while the shorted sensor blew completely staying open all the time. That is resulting in no heat.
If the temperature sensor has already been replaced, then problem is either wiring or oven electronic control. Wiring harness is tested checking continuity between different points.
Regards.
Ginko
Jul 17, 2011 | Belling XOU592 / XOU593 Electric Double...
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 | Ovens
Programming Belling xou181ss oven
Try Googling (belling)(xou181ss)(manual) without parens.
May 01, 2017 | Ovens
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Ovens Logo
65 people viewed this question
Top Belling Ovens Experts
Craig Butler
Craig Butler
RudeRude
Are you a Belling Oven Expert? Answer questions, earn points and help others
