Set the margin on a Sharp PA-3100II Intelliwriter
Holding down the green code key with the Right Margin key
JUSTOLDJIM
  • 478 Answers
SOURCE: Right margin won't release
Try touching the margin release key then the space bar to pass the margin then reset it in a new location with the right margin set key
Posted on Oct 17, 2007
Geno111
  • 183 Answers
SOURCE: electric typewriter set the margin
if you still have problem, repost with make and model typewriter, different methods are used with different machines
Posted on Nov 01, 2008
typewritrman
  • 32 Answers
SOURCE: Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Posted on Aug 31, 2009
JayBlair
  • 328 Answers
SOURCE: Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Posted on Sep 07, 2009
Testimonial: "Thanks for the information. We don't have aninstruction book with the typewriter. The grandkids like to play with the buttons."
  • 14 Answers
SOURCE: My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Posted on Oct 14, 2009
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
My Sharp PA-3140 II wont type after 13 characters. It worked fine yesterday, and now I turn it on and everything operates, but past 13 characters the wheel won't fire.
The right margin is probably set. reset the right margin further to the right. Use the MR key to release it, space bar over to where you want it & then set the right margin. RM (some time you have to use the code key or function key.
Mar 28, 2011 | Office Equipment & Supplies
How do I re-set the margins?
using the space bar or backspace keys, move the carrier to where youwant the margin set, you may have to hold down the "ALT" button (2nd key from left on the bottom of the keyboard) and hit the "3" button (the one under wher it says "MAR REL") , to move past the margin. When the carrier is where you want the margin set, hold down the ALT key and then hit he key under where it says L MAR (for left margin) or R MAR (for right margin). the ALT key accesses all the function listed above the keyboard, the CODE key accesses all the functions listed on the keys themselves.
Feb 28, 2011 | Brother ML-300 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
Oct 16, 2007 | Brother GX-6750 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
106 people viewed this question
k24674
jasbo
jasbo
