Hoe do I connect a sonytv KDL26EX302 to bt tv
Nothing yet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
In order to connect your TV - any sort - you need:-
1. A BT broadband package.
2. A BT YouView box.
3. A network connection to your HomeHub or other router.
If one of these is missing (or if your broadband connection is too slow) you will not be able to connect to BT TV.
If you have all 3, then on the TV select the signal source to the socket that the YouView box is connected to and it will be installed automatically.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 11, 2014
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Philips 46" 46PFL3608/F7 wont power on, no flashing LED nothing just a beeping coming from the power supply board.
HI,
first of all connect the tv to another power outlet in you home. If then also its showing the same problem Probably the power supply broad would be faulty. you have to check the power supply. if you are able to do it then this video will help you know hoe to check the power supply.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Sep 22, 2015 | Philips Televison & Video
Ido not understand how bt tv actually connects to my tv
Hello Mate
Is your KLV-32U300A have PCMCIA Card so you can connects easily your BT Tv. but if your TV don`t have that slot so sorry dear you have to upgrade your Tv. And I am surpizse that model is almost 4 to 5 years old, And its still works. (Nop its don`t have the PCMCIA CARD SLTS). Share with me you BT TV model or Device #.
Dec 11, 2014 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
I have connected PC to Yamaha and to SonyTV all with HDMI cable and when I play movie on my PC I can see the picture on TV but I can`t hear sound. What shoul I check to solve this problem? Thank...
Page 40 of your owners manual....
Rotate the INPUT selector on the front panel
(or set the operation mode selector to AMP
and then press one of the input selector
buttons on the remote control) to select the
desired input source.
Oct 19, 2010 | Yamaha RX-V2700 Receiver
Sonytv kv-hv21f83a no luminance
horizontal varde owar size sony tv model no kv-hv21f83a
Oct 03, 2010 | Sony Televison & Video
The remote control stopped working.
Check the remote lens on the TV for some dust and if present remove it. You can even use some alcohol to remove the dust. You can even try pressing the small reset button on the bottom of the remote after removing the batteries. Use new batteries.
You can get some help on how to repair a remote control from:
http://www.fixya.com/manuals/w153225-repair_remote_control
If nothing helps then you need to get a new remote... you get one from: http://www.newtvremotes.com/Mfrs/Sony/SonyTV/RM-Y906.htm
Jul 20, 2009 | Sony KP-53N77 TV
NO Signal KV32fv26 Sony Trinitron
I think your problem is in tuner stage.
1. Check 32V dc available on BT connection on tuner.
2.If 32V available on BT,connect dc meter and put the unit on auto search and check the BT pin on tuner.The BT voltage will decrease and increase while it tunes.
3.If nothing stored after programming replace tuner.
Good luck
Dals123
Oct 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
