I have a panasonic th-m50hd18 and when I try to turn it off there is nothing like it is getting no power at all
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 11, 2014
3 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: my Panasonic TH-42PX60U just turned
It is a power supply problem and if you replace the bad electrolytic caps, on the power supply, or just replace it will take care of your problem.
Posted on Feb 06, 2011
SuperTech-11
  • 1591 Answers
SOURCE: i recently moved my tv to my sisters and she
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
Leave it blinking for a while then try this:
If you repeatedly turn it off on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 11, 2011
I have a TH-M50HD18 PANASONIC PLASMA (18 months old) that becomes extremely hot to the touch after being on for only 30 minutes. (So hot that everyone I have asked to touch it for their opinion, jump back...
Check whether the cooling fans have stooped. Might be. If you wish to get more details about the positions of cooling fans inside, check the site linked here. http://electronicshelponline.blogspot.com/ It has disassembly procedure to this TV, which will describe all about it.
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 25, 2013 | Panasonic TH-50PHD3U 50 in. Television
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic plasma tv 50 inch 720p TH-M50HD18 red light blinks 10 times
In an earlier review I gave this product 1 star. Not because of its performance, but because I couldn't understand how to use it. The web site looked nice but was hard to follow. I really wanted it to work for me, but finally gave up. I really wanted this device to work for me, and now it does fitness tracker reviews
Jul 07, 2012 | Panasonic Televison & Video
Heard pop an my panasonic tv shut off. can't get it to turn on again
Power supply is suspect number one---in most cases there will be a for example 10 blink code from the power light---damage to the board may be hidden from view--so even if looked at you will see nothing.
Jun 11, 2012 | Panasonic TH-42PX60U Television
Are the tnph0716abs and the tnph0716ads A boards compatible?
no they two boards are slightly fifferent and will not interchange with each other. You should be able to get the proper board for your model from www.tvrepairworld.com
May 16, 2012 | Panasonic Televison & Video
Panasonic th-42pe7u had messages " SEE YOU NEXT TIME "
Only a thought here: next time it comes on enter and check to see if sleep timer is set to turn off set or not.
Apr 29, 2012 | Panasonic (TH-50PZ700U) Television
My 42in panasonic plasma viera blinks 10 times and will not turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Sound, No picture
Try another video source. Try a digital source and an analog source. If you still get nothing, think about replacing the DG board and the H board.
Dec 19, 2009 | Panasonic TH-42PZ77U TV
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
