Question about Franke Evolution
Need coffee to come out more as discs, not powder
What parameters do I need to change to get the waste coffee to be more like discs than powder.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Is coffee coming out? If yes ,then increase the gram age of coffee.
If no then coffee valve issue not letting enough water.
Posted on Dec 12, 2014
No express/water comes out. Powder coffee works well ??
Need the model you are using. You have done alot but some unit need more cleaning an checking.
Jan 29, 2015 | Coffee Makers & Espresso Machines
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
How much coffee do I use? I don't have a manual
The amount of powder required depends upon how strong or weak you like your coffee. I would suggest you start with around two thirds of a basket for a full brew and see how you find the flavour. Adjust the amount of powder used according to your taste. More powder = stronger coffee.
I can supply a manual if you need it but it doesnt specify an amount of powder to use.
Oct 04, 2013 | Bunn CWTF 15-TS Coffee Maker
How do i use cleaning powder
Hi Dont use the cleaning powder yet. Remove the group head shower and clean it with steel wool, then clean the group head where the shower sits with sfeel wool. Remove the filter fron the group handle and clean the under side. Also clean the group handle before you put the filter back in. You shouldn't use powder in these machines, but if you do, you need to put a blind filter (filter with no holes in it)in the group handle. If you dont have a blind filter, you can use foil to cover your filter. When you have done that, you need to add a 1/4 teaspoon of powder into the foil covered basket and lock the handle in the group head. Switch the coffee button on for a few seconds then off again.Domt take handle out yet. Repeat this on/off proceedure 5 or 6 times. Now remove the handle and flush out any powder that is left. Leaving the foil in place, lock the handle back into the group head and repeat the above proceedure. This fushes out any powder residue. Make a coffee and discard. Now your machine has bee back flushed. Again, i do not recomend using powder in these machines. The poder can back flow into the boiler. Just make sure you give it a good flush. If you clean your group head and shower weekly, you'll never need to use powder. Dazza COFFEE MACHINE TECHNICIAN
Sep 26, 2011 | Rancilio Silvia Espresso Machine
I just read that random dots being printed on the left side of all my documents means that i need to change the toner. I just changed the toner last week or the week before. Is this something that I call...
Hi
Well not often the problem is same, usually the toner cartridge will have 2 bins 1 is the hopper which holds the un-used powder and the other is the Waste toner bin which holds the waste powder. When it is full and there is no place to escape then the powder spills on the paper. But if this happens then you can just bang your toner lightly and in this was the air pockets in the powder is clear and spill will stop automatically.
PLEASE RATE MY SOLUTION
Jul 06, 2011 | HP LaserJet 1020 Printer
Water Problem
You might have a grinder issue. If the coffee is being ground too thin or too coarse it may cause an issue and no coffee will dispense. Here is the link to the grinder cleaning instructions: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Shop for Saeco parts and cleaning supplies.
www.CeriniCoffee.com
May 25, 2008 | Saeco Magic De Luxe Espresso Machine
Jura impressa s9
you need to clean / lubricate the "plungers". The normal clean cycle will strip off the lubricant over time. See my post here:
http://www.fixya.com/support/t348905-malfunction_8
Feb 18, 2008 | Jura Capresso Impressa S90 Espresso...
Coffee Makers & Espresso Machines Logo
55 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Yves
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
