Have a 1970s nelco electric baseboard with a switch and outlet for a wall air conditioner. Where can we order a new switch
Ha e looked at switch. Just old and wires are crumbling needs to be replaced. Where can I get parts
    Master:
  • 373 Answers
Go to the Digikey.com website.
Posted on Dec 11, 2014
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
We have a NELCO baseboard electrical heater, circa 1970s. We wish to remove it temporarily from the wall to permit new flooring installation under the heater. How are they attached to the wall?
It is attached with 2-screws or 2-nails. Depending on who installed it. I970's, I'm betting on 2-nails.
If you remove the cover, you will see where the nails are located on the inside back wall of the heater compartment and are attached to the baseboard. Be sure to turn the circuit breaker for the heater to the OFF position, be for attempting to unwire and move the heater. The circuit breaker should remain OFF until the heater is reinstalled.
Feb 28, 2011 | Fahrenheat FBE15002 Baseboard Heater
I have baseboard electric heat. My units are 27 years old. I'd like to replace with more efficient units but can't find any comparitive data.
Hummm, well, the newer units are trying to meet or exceed energy standards, so good on you for updating. You can look at Consumer Reports data to see which is best, but this method of heat does not lend itself to the same refinements as a gas furnace, for example.
I prefer units that have oil, or fans. The oil filled gives heat without having the heating element energized.
The fan units heat the room much better, but this is often NOT an option on baseboards, as many are wall cavity types.
220 volt costs less to run than 110 volt models, but this also is not something easily changed at this stage....
Oct 13, 2010 | Heating & Cooling
Square D (Nelco) MWA 2420 Forced Air with a broken heating coil
if its a coiled "nichrome"wire,get the wattage off of it and order a re-string kit from an appliance parts retailer and re-string it yourself,if its a solid-element as in an oven bake element then go direct to the company web site for replacement cause its probably a special shaped element
Nov 19, 2009 | Dryers
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Replacing a non-programable thermostat for electric baseboard heater with model CT410B. This is a 4 wire thermostat replacement for a previous 2 wire. Directions indicate that I can do this. I connect...
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Jan 23, 2009 | Heating & Cooling
Need electrical information for electrician to install new power
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
Dec 01, 2008 | Jenn-Air JDS8850 Dual Fuel (Electric and...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
