Question about Imation XtremeMac Soma Travel Stereo Speaker
I cannot get any sound when plugging in my iphone
    Sergeant:
  • 399 Answers
Is your stereo speaker turned on ? As far as I know, it does not come with an AC adapter because it takes its juice from whatever Apple device is plugged in. Maybe your phone does not have enough of a charge to power both the speaker and the phone. You could also try to turn up the volume on the speaker and/or the phone.
Posted on Dec 21, 2014
What do i need and how do i connect my iphone to my phillips FR 968 so i can listen to music??
http://www.manualslib.com/manual/128395/Philips-Fr-968.html?page=11#manual
Looks like you need an audio splitter to Left/Right mini plugs.
Such a cable goes from the earphone output on your iPhone to the CD in plugs on the back.
Alternatively you could purchase a bluetooth converter, plug it into your digital input, and pair it with your iPhone.
Mar 22, 2015 | Philips Fr-968 Digital Audio/video...
I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
Dec 02, 2014 | Denon Audio Players & Recorders
I HAVE SOUND BUT NO PICTURE
Make sure whatever your playing videos from is properly plugged in. iPod touch or iPhone (via HDMI): the iPhones and iPod touches don't show picture, just sound. TV (via Aerial): make sure is plugged in properly. If your TV remote has a Display button on it, press it again so it comes on. Hope this helps. Get back in touch. Steven :D
Jan 01, 2013 | Televison & Video
Bought my iphone 5 and am unable to charge using both the plug and computer. however am able to charge using the iphone 4 plug. please help!
Before you can charge your iPhone on the computer, your computer needs to install the drivers for it. You might have to reinstall the drivers for it. A good way to check if the drivers are incorrectly installed is to see if iTunes detects it. Try updating your iTunes since the old version of iTunes won't work with ios6 and all iPhone 5 are shipped with ios6
Oct 10, 2012 | Apple iPhone Smartphone
IPhone will not play over speakers. As soon as plugged in it says no volume available on iPhone. I'm pushing play/pause button and is on iPhone source
Usually the iPhone only supports certain headphone jacks into its system. When some devices are connected to the iPhone the iPhone does not produce sound because it does not support the device on the other end. The iPhone unlike the iTouch is sensitive to the kind of device which it is connected to most of the time.
Hope this explains the problem?
Jan 01, 2011 | Audio Players & Recorders
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
IPhone dont turn on
Keep the home and power button pressed for 10 seconds, then, leave power and keep the home button pressed...shud be able to see the charging cable logo...then restore it...
Jul 05, 2009 | Apple iPhone 3G
When I plug in my Iphone computer shuts down
It sounds like your usb port is damaged. Look in the port and see if there is any visible damage. Also, check the usb cord for the iphone and see if it is damaged.
Please take time to rate.
May 13, 2009 | Acer TravelMate 2480 PC Notebook
Iphone sound not working?
the iphone thinks it is still docked. Turn off the phone, then turn it back on and it should clear it. if not try restoring the phone in itunes.
This problem should not continue once restored, and if it does then see the people over at an apple store so they can make sure your phone is ok. They might even replace it for free.
Mar 29, 2009 | Apple iPhone 3G
How to get a2dp with iPhone
Best solution is to wait for iPhone OS 3.0. It is rumored to have a2dp support.
Feb 23, 2009 | Apple iPhone 3G
Imation XtremeMac Soma Travel Stereo Speaker Logo
54 people viewed this question
Top Imation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Imation Audio Player and Recorder Expert? Answer questions, earn points and help others
