Question about Hoover AAA160 Front Load Washer
-how do i open the filter
TO TURN IT ANTI CLOCKWISE
How do i change oil filter on 2011 toyota landcruiser v8
they unscrew counter clockwise .just like always .
Jul 01, 2016 | 2011 Toyota Land Cruiser
How to open filter on hotpoint aquarius 6kg 520h
you just turn it anti clockwise and if it doesnt turn there is probaly something stuck in it just get a pliers and wiggle it back and forward till it loosen up and should come out then
Oct 15, 2014 | Hotpoint Washing Machines
How to open filter on candy ctf 1005?
in the center is a screw you need to use a wide big flat driver
to carefully losten it anti clockwise
once its loose
you can use a cloth grab the center hold of the round pump cover and rotate it anti clockwise
the screw in the center is just used so the kids dont fload the house
Jul 27, 2014 | Candy Washing Machines
The filter bit at the bottom of the dishwasher, what does it look like? I need to know if i am missing a part?
To remove the filter
Turn the handle anti-clockwise to release the filter combination - 1
a. Lift the filter combination out of the dishwasher - 2
b. Remove any coarse particles and rinse the filter well under running water. Use a nylon brush if necessary.
To clean the inside of the filter, the flap must be opened:
^ Press together the catches in the direction of the arrows -1 as shown,
and open the filter -2 .
^ Rinse all the filters under running water.
^ Then close the flap so that the catch engages.
Nov 17, 2009 | Miele Dishwashers
How do I open the filter on a Hotpoint WML 520P
my hoover has a screw in the filter cap you have to remove that then turn anti clockwise hth
keith
Sep 18, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
Zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Jun 15, 2009 | Zanussi F1245W Front Load Washer
Hoover AAA160 Front Load Washer Logo
48 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
