Question about Honeywell DOLPHIN 6500:5300SR IMGR/28KY 128X128MB/80211BG/BATT/PS/BT
Re phone BT6500, how does one increase the number of rings before it goes to answerphone?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Honeywell Master
  • 884 Answers
Hi
I give below the step by step procedure for changing the number of rings the phone will sound.
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press until Settings is displayed, press Select.
3. Press to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use or to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Be aware though that the number of rings needs to be less than your ansaphone service, for BT 1571 this is 5 rings, although more may be possible if you can get BT to change their 1571 for your line.
For more information about your phone you can download a pdf format manual from here:
https://www.shop.bt.com/content/uni2/documentation/8h3j/bt6500_user_guide.pdf
This can be saved to hard disk for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 11, 2014
How do I increase the number of rings before the answerphone starts
Google make, model and manual. Download the manual, and can find out what ringer adjustments you can make.
Mar 08, 2015 | Lands Phones
Why won't my answerphone work properly?
Either you must set your home answering machine to answer on fewer rings OR disable the phone company's message system.
Nov 19, 2011 | Lands Phones
How do i reduce the number of rings before the call goes to answerphone? The phone is ringing about 8 times before it switches to the answerphone and I would like this to be about 4 rings
usually there is a small slide switch on the side of the answering machine that you can use to control how many rings before it answers. if that is a new digital model you will likely have to go into the menu to set it up. often your choices are two, four or toll saver.
robert
Please take a moment to rate this solution thanks
Nov 10, 2009 | Nortel Lands Phones
How do I increase the time between the phone ringing and the answerphone coming on?
It really depends on the type of machine you have. Some have a sliding indicator on the side or bottom that is for the number of rings depending on where the slide is. New models can be programed from the handset by going to menu, then initial settings, Answering, then number of rings. Type the number of rings at the prompt and hit save. That is how my new machine works.
Oct 26, 2009 | Lands Phones
Answerphone Question
Push Menu, Scroll to Initial Setting and push Select, go to Set Answering and push select, go to Ring Count and push select, you should be able to scroll up or down to the number of rings, in your case 6, and then push save
Mar 12, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
We have an se445 cordless phone/answerphone. with answerphone on, the line rings 4 times then stops briefly before continuing to ring instead of cutting onto answerphone. BT line has been checked and gain...
Regarding the Philips SE445 cordless phone/answerphone. I posted my problem where it rings 4 times then continues to ring without cutting into the answerphone. My phone is now fixed and working as it should which is great. I was unable to make calls because I had no dial tone and although Virgin checked my line and said it was fine, it obviously wasn't. The problem was with the line in the Exchange Box - the big green boxes that are located on the roadside - the line was broken there. Once fixed, I had my dial tone and the SE445 is working perfectly. To nomad1066, I would insist that BT check their Exchange Boxes as this is probably where the problem lies. Check whether you have a dial tone. Hope this helps.
Jul 24, 2008 | Lands Phones
Ring time too short
try resetting your phone to its factory settings...
Dec 19, 2007 | Samsung SGH-U600
Honeywell DOLPHIN 6500:5300SR IMGR/28KY 128X128MB/80211BG/BATT/PS/BT Logo
106 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
