Question about Radio Communications
Need a charger for a 2-way radio. - Radio Communications
  • kakima Dec 11, 2014
    For what make and model radio?
    Problem Solver:
  • 25 Answers
What is the model of the radio?
Posted on Dec 12, 2014
Where can I find a charger for audiovox 2 way radio model FRS100Y
I have a 4 radio wall charger in a motorhome where the radios were missing. It is FRS4WM. I am willing to sell it. Bob
Mar 22, 2013 | Audiovox Radio Communications
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Is not charging batteries but it will play off the batteries
Check iside radio, there is a metal box which is your charger unit. You need to undo the 2 phillip screws on the charger housing to gain access to the fuse inside which is a 2 amp.
Oct 02, 2009 | Dewalt DC011 AM/FM Radio
Dangers of a Motorola being left on when charging in a multilpe
Don't know if you'd call it dangerous, but wisedom would be not to leave a radio turned on while on the charger. 1) Shortened battery life due to short charging. The battery will never be fully charged due to powering the radio. 2) Inadvertently pressing the PTT button while the radio on the charger can/will burn out components in the radio including the PA (final amp) which is a costly repair.
Instead of leaving the radio turned on while on the charger, buy a second battery to keep on the charger. Then you only need to swap batteries. Your radio would be able to remain on, and never be on the charger.
Jun 28, 2009 | Motorola Radio Communications
Need battery charger
Bought a universal charger from Radio Shack with plug that match spotlite.
Jun 23, 2009 | Duracell Crank Light 3 In 1, 3 Led...
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
I need an electrical connection for 2-way Radio charger base.
Check the voltage of the battery and pick something 1-3 volts higher.
If you have an ohm meter you can meter between battery contacts and charger wall wart jack and see which one is positive and negative and match your transformer up to it.
Jan 16, 2009 | Cobra 2 mile FRS 2 pack Value Pack with...
What kind a charger i need for it
The FV200AA, as indicated by the AA, is the AA battery version of the radio, and does have a charger. If you are using rechargeable AA batteries you will need to charge them separate from the radio in the appropriate charger.
Jul 18, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Lost the charger for T5720 cradel, need voltage specs for replacement
HI,
The charger cradle for this model is 220V.
Hope this helps
May 24, 2008 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
