Question about Weedeater Garden
My twister weedeater sb180 30cc will stay running
  • Eugene Rounds Dec 11, 2014
    Clarafication needed. Can not turn off or is it wouldn't stay running?
I have a husqvarna128 weedeater already cleaned the carb not the prob it will only stay running if the choke is halfway and you pump the throttle any suggestions?
Its definitely the carb. "cleaning" the carb usually is not a fix alone on those 2 cycle carbs. You should rebuild and clean it. The small diaphrams in those get tiny holes, and the fuel now days plays havoc on them.
Carb kits are inexpensive, just make sure you re-assemble everything in correct order.
Apr 13, 2016 | Husqvarna 128 LD Weedeater
Weedeater 25cc Blower
Its obviously fuel starvation, start withe the easy stuff first, use a peice of bent wire to hook the fuel line out through the open filler hole, the filter on the end then needs to be pulled off and replaced, try this first before we get into the carb.
Jun 25, 2013 | Garden
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
PRESTO Tater Twister Instuctions
  • 1
    Take the inner piece of the Tater Twister, the large white circular piece, and place upside down on the table. The two handles should be on the bottom and not the top.
  • 2
    Choose your cutting disc and insert it into the inner piece of the Tater Twister. Insert the disc with the bladed side facing downward. There are two tabs on the side that should snap into place on the inner piece of the Tater Twister.
    • Free Daily News on your Cell Phone. All news on potatoes & products
  • Plug in the main Tater Twister unit, the glass blender-like piece. Insert a potato or other vegetable into the Tater Twister. There are several small studs sticking up in the bottom. Push the vegetable down onto those studs to hold it in place.
  • 4
    Push the switch on the front of the Tater Twister to turn it on. Take the inner piece and turn it right side up so you can hold the two handles.
  • 5
    Lower the inner piece into the Tater Twister. Position it so the handles line up with the two large slits in the Tater Twister. As you push down, pieces of the vegetable are pushed through the cutting blade.
  • 6
    Continue pushing until the inner piece has reached the bottom. Turn off the Tater Twister by pushing the switch on the front into the off position. Take out the inner piece and dump out the cut vegetable pieces onto a plate.
  • Parts For Porsche Panamera
    Jun 15, 2012 | Cell Phones
    Model ut21004 homelite gas weedeater want stay
    fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
    May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
    Garden Logo
    78 people viewed this question
    Top Weedeater Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    Darrell
    Are you a Weedeater Garden Expert? Answer questions, earn points and help others
