Question about Toshiba SATELLITE PRO C70-A SERIES Laptop Screen 17.3 LED BOTTOM LEFT WXGA
On a Toshiba Laptop C70-A Series , lost my arrow and some keys dont work. How can I get my mouse back, so I can do a backup ?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
Depending on your laptop settings start by doing a FULL shutdown. After rebooting hopefully the mouse (assume you mean a touchpad) will be restored; and maybe the keys not working. If unsuccessful connect a USB mouse and USB keyboard and check settings of the touchpad and also select the default language keyboard. If still unsuccessful try reinstalling touchpad drivers. Consider a possibility of some problem or damage to the keypad and/or touchpad if this all happened recently and the above doesn't correct.
Posted on Dec 11, 2014
Sometimes when I am on my laptop the arrow for my cursor disappears and I can not do anything unless I can get the arrow keys to take me to something.
Go to the Control Panel, using the menu (keys control+ESC).
Using the arrow keys.
Using the tab keys go to mouse icon and then pointers and make the changes to reveal the cursors.
Feb 19, 2015 | Toshiba Satellite Computers & Internet
Where would the reset button be inside a laptop.
Disconnect the power, remove the battery then press and hold the power button for 15 seconds. Reassemble.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
Dec 11, 2014 | Computers & Internet
Lost th arrow on dell laptop
If the arrow does not appear, it usually means that Windows did not detect a mouse. A quick and easy way to test this is to plug in a USB mouse from a desktop computer. If your arrow returns, that confirms Windows does not see your mouse. If this *is* the case, then go into the BIOS screen (F2? when booting) and look through the menus to make sure mouse is enabled. Also make sure to look for an option under "Dock" that says something like disable mouse when docked. If plugging in a USB mouse does not make the pointer re-appear, then you may have windows problems. I'd try easy things first, like re-installing the mouse driver for your laptop. This especially if you have a fancy driver for multi-finger gestures 8-). While you work on this, try the Tab and ALT-Tab keys to move the focus around on your desktop. The Start menu also springs up with the Windows key. Space and Enter are like clicking. ALT-Enter like right-clicking.
Apr 01, 2014 | Dell Latitude E4310 Laptop
Touchpad not active
Press the "Fn" and "F9" keys simultaneously.
Test your touchpad. If it works, it was simply disabled. Press the same key combination any time you want to toggle your touchpad on or off.
Plug an external mouse into a USB port on your laptopicon1.png if the key combination didn't work. Follow onscreen prompts to install the mouse driver--if necessary. You can also move the cursor using the "Tab" key and the arrow keys, as well as click by pressing "Enter" until the mouse is operational.
Click the link in the Resources section if you are using a Toshibaicon1.png Satellite with Windows Vista. Follow the onscreen prompts to download and re-install the driver.
Open a web browser and navigate to Synaptics.com if you have a different Toshiba model or operating system. Synaptics brand touchpads are used in all Toshiba laptops, and this site provides a generic driver.Hover your mouse over "Support" on the top menu, then select "Drivers" from the drop-down menu.
Select your operating system from the list provided and download the generic driver
Follow the onscreen prompts to install your new driver, and then test the touchpad again. If it still does not work, take your laptop to a licensed repair technician.
Jan 06, 2014 | Toshiba SATELLITE 1905-S301 TOUCHPAD AND...
Gateway NV59hu series laptop keys stop
have you spilt something onto the keyboard at all?
Sep 27, 2013 | Gateway Nv57h57u Laptop
Reinstalled XP after putting in new HD. Delay issues
Is the HDD same as the previous one? I mean the specs. These laptops are very HW specific while desktops are free of any such problems. Moreover, Did you reboot the laptop before and after reinstalling the mouse drivers? please follow the procedure in the link below:
Installing Devices on PCs and Laptops
May 16, 2010 | Toshiba Satellite A75-S226 Notebook
Mouse not working on a toshiba portege 3110.
I see your delema i would normally agree with beast_b9 however i fail to see how you can "right click". I recommend:
first put these instructions on paper
on your key board press Windows key + pause break
press tab untill it highlights the general tab
now with the right arrow go to hardware tab
press tab until device manager is highlighted now press enter
press tab and with the down arrow go down to "universal serial..."
press the right arrow and go down to usb root hub
press enter and press tab untill the general tab is selected
go right untill you reach driver tab
press tab utill rollback driver is selected
now press enter
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Computers & Internet
Toshiba Satelitte 100/105 series won't boot up. When you turn it on it does the loading your settings, show desktop background, and then logs you off. We have tried removing the power and holding down the...
have u got factory backup disk for OS , actually i just repaired my laptop affected by Conficker , so u just need the factory backup OS disk to repair ur pc otherwise changing hard drive in this case wont help conficker cant damage the hard drive it just stops some policies and services and make ur computer slow and un usable with out network access dont worry just get a backup disk and install it
i can guide u thru if u want me !
Apr 06, 2009 | Toshiba Satellite A135 Notebook
Toshiba equium A210 series laptop key board stops working.
GO INTO CONTROL PANAL GO TO FOLDED PROBLEM AND REPORTING AND OPEN IT
LOOK FOR ANY MARKING THAT SHOULDNT BE THERE, GREEN MARKINGS IS GOOD BUT ANYTHING ELSE TROUBLE AND DOUBLE CLICK ON THE CHECK MARK AND FOLLOW INSTRUCTIONS
ROD
Feb 12, 2009 | Computers & Internet
Need to reset display settings
Hi
Take a look at the keyboard and find the FN button on the bottom left. (The letters FN are in blue)
Now look at the F keys at the top of keyboard and find one that has either a couple of monitor symbols or the letters CRT/LCD - again in blue
Holding down the FN key and press the other key, this should change screens between the external and internal monitors. Don't expect an instant change - it sometimes takes a couple of seconds to do the job.
If that does not work then attach another external monitor, right click on the screen and select properties. Now select the far right tab (settings) and then go to Advanced tab and then select Monitor
Here you should be able to change screens back to the LCD of the laptop
Dec 09, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba SATELLITE PRO C70-A SERIES Laptop Screen 17.3 LED BOTTOM LEFT WXGA Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
