Http://waterheatertimer.org/How-to-set-timers.html
Step by step instructions
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
SOURCE: GE 24 hour programmable basic timer - how do i
So, this timer came with no instructions. What do you want for $3.99. Made cheap in China and instructions cost more than the timer.
The timer has a dial with tabs all around the 24 hour clock. They are in the down position which is on. You must pull all the tabs up in the times you want the timer off. This is different from all the other timers I have that used that have two removable tabs that are placed at the start and end times.
Put the switch on the side of the timer in the timer position.
SOURCE: I just purchased a Woods TN300 Timer. I have it
Make sure
the manual override switch on the unit is set to timer on.
SOURCE: wondering how to use a
Pins are usually up for on and down for off, so put them to on for the times you want the lamps on and vice versa, obviously you can check firstly to be sure which way is on and which way is off.
SOURCE: i do not know how
Open following link to identify timer, with information for trippers and replacement clock motor:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
The clock motor rotates analog timer dial clockwise as time passes.
Trippers on the dial move lever that rotates a cam that opens and closes electric circuit.
To set current time, manually rotate timer dial until current time lines up with the word Timer located near the 5 o'clock position.
If the dial is not rotating oe keeping good time, then clock motor is bad.
If trippers don't move the lever, then trippers are worn down.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
