Parts for shinco outdoor pcb - Heating & Cooling
Have a shinco ap14000 portable ac the p2 icon is on what does that mean ?
FAULT = ELECTRIC CURRENT IS TOO HIGH.
CODE = P2
CHECK POINT = 1. CHECK IF THE REFRIGERANT IS CHARGED TOO MUCH
2. CHECK IF THE VOLTAGE IS TOO LOW, POWER WIRINGS TOO THIN OR TOO LONG OR CONTACT BADLY.
3. CHECK IF THE OUTLET IS BLOCKED OR THE CONDENSOR IS DIRTY
4. CHECK THE OUTDOOR MOTOR WORK NORMALLY
COUNT MEASURE = 1. REGULATE THE QUANTITY OF REFRIGERANT
2. UPDATING POWER SUPPLY, CHANGE POWER WIRING
3. REMOVE OBSTACLE AROUND OUTDOOR UNIT OR WASH THE CONDENSER
4. CHANGE OUTDOOR MOTOR OR MOTOR CAPACITOR
Aug 03, 2017 | Heating & Cooling
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
The red light is flashing on my air conditioner SHINCO KFR 50GW, and the outdoor unit is off?
Sorry didn't really know how rusty me Japanese was until I went on their support page and could not read but half good luck
Jul 03, 2015 | Heating & Cooling
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
How do I fix error code F99 on a panasonic air conditioner
F99 Fault: Outdoor Direct Current (DC) peak detection
Causes: • Outdoor PCB (replace);
• IPM (Power transistor) (replace - normally part of the controller PCB above);
• Compressor (replace);
Jan 18, 2015 | Panasonic Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
I am trying to get a users manual for a Shinco pmp 1700 multi media portable player.
I've not been able to find a digital copy of the user manual for you, your best bet is to contact shinco for a user manual and see if they can send you one over email or mail you a physical copy.
Here is their email address support@shinco.com.sg
you can also try
HC SHINCO (USA), INC.
330 Turnbull Canyon Road, City of Industry
CA 91745
Tel: +626 968 8827
E-Mail: edl@concept-intl.net
enquiry@shinco.com.sg
bill@shinco.com.sg
Jul 07, 2011 | Televison & Video
I have a 8.5" Shinco SDP-6820 DVD/DivX Player The
how do I want to buy a spare part is optics of a type 6820 Shinco portable dvd silver
Jun 09, 2010 | Televison & Video
Air conditioner shuts off
C5
Communication Error
• Wrong or missing wiring between indoor and outdoor unit cable
• Defect of communication components in indoor pcb assembly
• Defect of communication components in outdoor pcb assembly
• Defect of power supply components in outdoor pcb assembly
• No ground connection in air conditioner unit
(affected by noise in power source)
Jun 30, 2009 | LG Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
