Question about Kitchen Ranges
How do i unlock the dóor seized last night after washing a meduim rug
Everything
  • 3,368 Answers
I would recommend getting a service tech to help you before you damage the unit more then it is. Normally I wash my rug in a washer not on a range:-)
Posted on Dec 11, 2014
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Tip
THANK YOU !!!!! and thanks to my 15 yr mechanically inclined son...he did do...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jak sciagnac simlocka za darmo z sony ericsson w205 kodem
mo?na odblokowa? telefonu kom?rkowego, przez kody odblokowuj?ce .. bezpiecznego i najlepszy spos?b na odblokowanie jest przez kody odblokowuj?ce i m?j osobisty wniosek, ?e nie id? do odblokowania oprogramowania, poniewa? czasami oprogramowanie mo?e dosta? uszkodzeniu i dane zostan? utracone w wyniku ?e i r?wnie? dont go za darmo odblokowania poniewa? kod wygenerowany za darmo mo?e p?j?? ?le czasami jej moje z?e do?wiadczenie, wi?c poszed?em do odblokowania za pomoc? kod?w z classicunlocking i unlocked.you mo?na te? spr?bowa?, ale patrz na to czy tw?j kraj i operatora znajduje si? na li?cie .. bo dla niekt?rych us?ug tylko kody s? dost?pne .. sprawdzi?, ?e i gdy w danym kraju dostawcy znajduje si? na li?cie a nast?pnie uzyska? kody i odblokowanie telefonu kom?rkowego ..
Oct 22, 2011 | Sony Ericsson Cell Phones
VUI LONG CHO TOI MAT KHAU ULTRA MAOINOKIA7610 CUA TOI CO IMEL LA 354330004155043
h?y th? trang web n?y. M? Unlock-Free.com n? s? gi?p b?n ?? c? ???c m? s? ?? m? kh?a ho?c thi?t l?p l?i ?i?n tho?i c?a b?n.
Aug 23, 2011 | Nokia 7610
Okay so i was washing my daughters rug, that's fine to go in the washing machine and now it wont drain the water, The rug drop all this lint stuff, I've taken the rug out of the washing machine and i cant...
My guess is that something has plugged the filtere trap below the tub. Depending on wht model you have you can acces the trap from the front panel or rear panel. Get a bucket hand beacuse water will flow when you open the trap. If this gets clogged your machine will stop. dcramer531_75.jpgdcramer531_76.jpg No mater what machine you have the filter will look something like this, once it is cleaned out you will be good to go. If you like my free advice I would appreciate the 4 thumbs up vote and glad I can help.
Feb 05, 2011 | Washing Machines
Ok i have a problem i bought a iphone from my friend last night so he restarted everything and its been on the same screen for the whole night last night i dont know what to do i tryed restarting and...
. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
when you see the silver Apple logo you can let go of the buttons.
and then try the phone and see if it is ok now
good luck
Jul 29, 2010 | Apple iPhone Smartphone
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Control lock on front load whirlpool washing maching
find button with lock emblem under it ..hold button down for 3-5 secs
Jun 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
