Question about Vizio L32 32 in. LCD HDTV
Hi, Typical I leave the my bedroom tv on upstairs it's a Vizio 32' HDtv well typical after a few hrs it well have a notice on screen that there has been no changing of the channel it
I have turned it off and on. Also I have reset the cable box.
  • Vizio Master
  • 1,210 Answers
The Knight answer is correct. In almost all cases, Vizio TVs will have the T-con board built into the Signal board (You may call it the Main board as well), but in short other problems in the signal board are present. The board,Knight is referring to, has all your RCA jacks, RF connector (for cable TV) computer vega and component connections. Replacing this board will correct your TV. I have repaired many Vizio TVs.
Posted on Dec 28, 2014
    Top Expert:
  • Vizio Master
  • 74,106 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 11, 2014
Vizio tv volume up & down doesn't work
Check and replace its main system memory IC.
Oct 05, 2012 | Vizio L32 32 in. LCD HDTV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
I purchased a Vizio 32' VA320M off of ebay and it arrived today, I hooked it up watched it for a couple hours this morning, played a little xbox on it and went to sleep. I woke up tonight and was...
This tv have the main Tuner signal board have intermitten problems.Return this tv for a refund.Can't return it make a claim with Ebay,Pay PAL or ur credit card if pay by credit cards.
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Hi, my 32' Vizio won't turn on and the orange idle light does not come on either. Before this happened I would have to turn it on 3 - 7 times before it stayed, meaning I would turn it on then it would...
I had a problem with a Vizio L32 not turning on. I found a solution at http://www.ecoustics.com/electronics/forum/home-video/429280.html provided by Daniel Powell. The solution for me was to locate the part U26 on the video processing board, and to bridge pins 2 & 3 with a diode as described. I didn't have to remove U26 in my case. I was very surprised to find that this solved my problem.
Apr 21, 2011 | Vizio L32 32 in. LCD HDTV
My vizio 32" tv won't turn on, only the red led light does. My warranty expired one week before the tv stopped working. can you please help me
I would try real hard to get it repair under warranty, they may bend the rule sinc it is only one week over warranty. Right now the 5vdc standby power supply is working. Typical repair for LCD TV is $200 and up plus parts. If they refuse, I would not buy another VIZIO.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 21, 2010 | Vizio VW32L 32 in. LCD HDTV
Can I purchase a replacement screen for my vizio v0320e
you can try this place that sells lcd parts shopjimmy but typically the lcd screens cost more than a new TV does.
Apr 06, 2010 | Vizio L32 32 in. LCD HDTV
CVizio 32" background lamp won't stay on
Ur backlight inverter ic board is dead must be replace.
Aug 31, 2009 | Vizio L32 32 in. LCD HDTV
The TV will not turn on, any typical problems?
Not focused at your model pacifically. Typical problems like yours are happening to lots of other flat screen TVs in other brands.
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Dont know the contrast ratio of this tv
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
May 23, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
59 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
