Question about Kitchen Appliances - Others
Make ice but it doesn't come out of harvest - Kitchen Appliances - Others
  • howard thompson Dec 15, 2014
    Hi Nelson Zometa, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number?
  • 100 Answers
Bin senor could be going out or need to be clean. ...when ice falls ,see if machine recognizes it..if not it'll stay in harvest and eventually go out on a refrigeration code
Posted on Jan 15, 2015
HOW DOES A MODEL 315P ICE MACHINE GO INTO HARVEST?
The ice machine has a HARVEST TIMER. You can adjust the harvest time, it comes from the factory for 3 minutes. You should not have to adjust it 3 minutes is plenty of time if every thing is working right. If the machine is operating making ice but not falling in storage bin then check these possible cause.
1. ICE may be stuck in the evaporator and the unit is " frozen up "
POSSIBLE SOLUTION: Clean and sanitize.
Possible Cause: Harvest time set too short - timer needs adjustment.
2. Harvest timer bad: replace harvest timer.
Jun 24, 2014 | Kitchen Appliances - Others
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Water doesn;t stop
I don't know a lot about this machine but it could be that the water inlet value is not working correctly
Apr 07, 2014 | Franklin Industries Franklin Chef Ice Cube...
How to get ice going
First is the machine making ice ? If it is making ice is it thick enough so the water comes in contact with the ice thickness probe. This has to happen so the machine will know it needs to go into a harvest. You should not have to fores it into a harvest it should be doing it on it on. There is a harvest button on the CM3 controller but when you push it its going into a harvest and when it finishes the harvest it will shut the machine OFF. I really need more info. What is it doing or not doing?
Mar 19, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman CM3 does not harvest and does not refill
Remove the ice thickness probe that is hanging at the top of the evaporator plate and clean really good put it back push the freeze tab. If the ice is still getting to thick and not causing the machine to go into a harvest then replace the probe , make sure when you do this to set the thickness by using a 1/8 inch drill bit, lay the bit flat between the evaporator plate and the probe turn the 1/4 screw in or out to achieve the 1/8 inch. The probe is what sets the machine into a harvest, if the ice is not building up enough to cause the water to come into contact whit the probe long enough then it will not go into a harvest. if the ice is getting to thick and the water should be running over the probe it should have went into a harvest if not then the probe is not sensing it to tell the CM3 to go into a harvest.
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cm3 does not harvest
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scottman cu3030 max harvest-retrying, flashing code #2
The machine will try to harvest 3 times before it shuts the machine down. Is the ice thick enough to open the curtain door? if the curtain dose not open the magnet switch then the machine dose not know it has harvested the ice and will keep trying to harvest. Is the ice coming off the evaporator plate during harvest or is it hung on the plate? if hanging on the plate then system needs to be cleaned. is the harvest assist plunger working?
Oct 30, 2013 | Scotsman Refrigerators
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
