Question about Water Heaters
Recently we.had to have the motor replaced on our 3 year old Navien Combi boiler/tankless water heater because it made a squealing noise periodically. The technician who worked on it told us to let him know if the new one made the noise. Around 3 weeks later my husband noticed it making the noise again but only periodicaaly. The heating company we bought it from cannot determine what is wrong with it and basically washed their hands of it. What could be wrong? Is it another faulty motor or could there be another problem? Is this a common Navien Combi boiler problem.
  • 4 Answers
This could actually be a manufacturer issue with the brand of pump. Based on your description it is unclear if this is a circulator pump, fuel pump, zone valve motor or other motor on your appliance. As a 30 plus year technician of heating appliance I have seen many parts factory defective, especially when purchased at the same supply house. Inventory is typically shipped to supply houses with manufactured parts from the same factory lot numbers, and when this happens, the technician keeps replacing a part with parts from the same bad lot!
Also, not knowing the true details of this situation, the installation set up, piping sizes, component brands, what means of air venting system was used in the hydronic side of this system, if any? With that said giving you a more specific answer is really impossible, based on the little knowledge I have to go on to help you out.
My recommendation would be to contact another company and have them come out to look at the problem, if you find the previous company charged you for parts that were not needed or the system was installed incorrectly, contact your local plumbing inspector for what to do in your area.
Posted on Dec 13, 2014
5 Suggested Answers
  • 30 Answers
SOURCE: vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Posted on Mar 30, 2009
mcgyver468
  • 710 Answers
SOURCE: noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Posted on Apr 24, 2009
gary1121
  • 332 Answers
yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Posted on Jun 06, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
In temperature screen at 49 degrees to back to front t's appear and boiler stops
PDF]Operation and Installation Manual Outdoor Tankless Water ...
https://www.rinnai.us/.../U287-1932(00)_Outdoor_...
Rinnai America Corp.Temperature controlled continuous flow gas hot water system. .... This water heaterwill attempt to provide hot water at the temperature setting even when the ...
Hot water system temperatures and the code ' Plumbing ...
plumbingengineer.com/content/hot-water-system-temperatures-and-code
Feb 1, 2015 - There have also been incidents where the circulating pump stopped ...before it connects back to the cold water inlet to the water heater. .... Is there a maximum temperature limit for domestic water heaters? ... a means to limit the maximum setting at the valve to 120°F (49°C) or ... Some do and some don't.
[PDF]User's Operation Manual - contents - Navien
Dec 25, 2015 | Water Heaters
I have a Navien NR 240A tankless which has been in use for about a year. My only complaint is that when the internal recirculation pump turns on I can hear a waterflow or pump noise throughout the house...
Hi Bruce
No its not normal it shud b isolated by lagging the noise travels through the timber lagging between pipes will help also how old is the pump shud only b a hum if pump ok any more and u need to replace , also u mite like to check speed of pump mite b on max turn down so long ur flow is ok or ur system mite get to hot
Sep 17, 2013 | Water Heaters
Loud vibration
1) What brand and type water heater? Gas or electric? Tank or tankless? Or boiler? Solar assisted? Indirect? Wood-burning? Oil-fired? etc?
2) How old is heater? Is this a new installation? Or installation that worked before and vibration is something new.
3) Or are you talking about a washing machine instead of water heater? Or hair dryer? Or GMC truck?
4) Add a comment and give more exact information from label located on side of unit, for possible assistance.
Feb 18, 2013 | Water Heaters
Bosch 125fx heater barely heats water
1) Recommend replacing tankless with ordinary tank-type gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/Which-is-best-gas-water-heater.pdf
2) Tankless cannot be exposed to more than 11 grains hardness in water or unit will fail within 2-5 years. Water softener is required.
http://hometips.me/Tls/Battelle_Water-softening-research.pdf
3) Descaling tankless water heater each year will not restore functionality, or restore efficiency of tankless, nor restore full efficiency to tank-type gas water heater.
4) Bradford White side-by-side testing research comparing their tankless with their tank-type shows that tankless will save $1-8 per month on energy bill vrs ordianry tank-type ....but conclude that tankless 'fall far short of payback' due to maintenance, repair, installation and replacement costs.
Study compared full cost, and not just monthly energy bill, since All costs are energy.
Feb 16, 2013 | Water Heaters
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Aug 06, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
I have a combi boiler and a 'popping' hot tap
the lock nut has either come loose under the handel or the 'o' ring and stem have loosened up, might this be a delta faucet? if so replace the cartridge "stem" and the o-ring and spring you will be fine,,
Jun 09, 2009 | Rheem Tankless water heater for 1-2...
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Water Heaters Logo
118 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
