Question about Technics Audio Players & Recorders
How do I fix the tonearm of my Technics SL-1950 so it doesn't keep pulling to the right when in neutral balance?
I've tried spinning the platter clockwise ten times as the manual suggests, but the tonearm continues to pull right. I would like to avoid placing more weight onto the record by adjusting the balance to the headshell is heavier, but so far, that's the only way that it will track properly.
  • Jonathan Hurst
    Jonathan Hurst Dec 11, 2014
    Never mind. Managed to fix it. I was calibrating the balance wrong.
    Scholar:
  • 173 Answers
The anti-skating control adds an outward pull to the arm to compensate for the inward pull exerted on the arm when a record is being played.
Setting the anti-skating control to "0" should virtually eliminate the drift you mention when the arm is in neutral balance. Also make sure that the whole unit is level as this may also affect the arm's tendency to drift.
Posted on Dec 13, 2014
  • Jonathan Hurst
    Jonathan Hurst Dec 13, 2014
    Thanks John! I managed to figure it out. I was calibrating the balance incorrectly. Once I actually saw someone do it, it made much more sense than just reading it and I was able to correctly calibrate it.
Benimur
  • 6966 Answers
SOURCE: Technics sl-1200 tonearm problem
Hi, Assuming the the turntable is on a level platform and that you have "adjusted the weight and anti skating correctly", might it not be just the styli/cartridge that's left in question? Visually check the styli/cartridge assembly, look for unevenness of wear on the needle itself, compare with a known good styli the angle. On some rare instances, it is the shielded wire inside the arm. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 30, 2007
SOURCE: Technics SL-1600MK2
Tonearm lift is probably a deteriorated belt. Google it, it's pretty common. The platter spinning might be due to a bad control board. You'll probably have to go to a repair shop to diagnose it.
Posted on Oct 27, 2008
dunnbiker
  • 8546 Answers
SOURCE: TECHNICS SL-1650 RIGHT CHANNEL IS OUT.
No continuity means you have an OPEN, not a short.
Before you tear the tonearm apart, check each of the 4 contacts for continuity to the various RCA cable conductors. Two will be to the outer conductors (ground) and each of the other two should have continuity to one and only one center conductor, NO grounds.
The wires are very fine and crimps may have failed, or oxide has built up on the contacts within the headshell. Sometimes repeated plug/unplug action will clean them up.
Posted on Nov 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: having trouble with adjusting tracking weight for concorde pro s
The manual for the SL1200 (same machine but silver, acccording to an online reviewer) says:
"An auxiliary weight may be necessary between the
cartridge and headshell, mostly in a DJ application.
Many new cartridges and new turntables come with
these weights. If you cannot achieve the recommended
tracking force, then this weight is what will be needed."
Posted on Mar 01, 2010
Deneenie
  • 73 Answers
SOURCE: I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Posted on Feb 22, 2012
Skip repeats halfway through
Sounds like to much anti-skating with an old stylus. That can pull a needle back over and over again around the center of the record.
Try setting the anti-skating at 0% and see what happens. Also set your tonearm height to level with the platter. These may not completely fix the problem (may need new stylus tips) but shout make a huge improvement
Jan 28, 2014 | Technics SL-1200MK2 Turntable
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
Tonearm doesn't automatically return technics sl-d 202
Hi, at the base of the tonearm (left side) you will will find a rubber grommet or hole. Insert flat blade screw driver. Adjust until tonearm is lifting at end of record. Cheers john.
Apr 09, 2013 | Audio Players & Recorders
The arm just slides across the record.
The link for this model's manual is a dead-end at the Panasonic website. I lodged an email complaint.
If the tonearms balance and anti-skate are set properly it should track correctly.
When you lower the tonearm does it actuallu drop onto the platter or does it seem to hover? Look at the stylus to make sure a dustball hasn't clogged the tip.
Jan 19, 2011 | Technics SL-BD20D Turntable
How do you balance & adjust tonearm after changing stylus
turn the whole weight until arm sits just above platter.hold back of weight and turn front disc to zero. turn whole weight to spec for cartidge fitted,usually around 2.
Nov 21, 2009 | Technics SL-1200MK2 Turntable
Technics 1210 MK11 - 'Click' in tone arm movement
It's clearly a mechanical interference under the hood, so to speak. If you're comfortable with this, unplug the power and signal from the TT, remove platter and manually rotate the tonearm across its arc, listening or feeling for the drag. Maybe you will see the cause with the platter off.
If not, remove the headshell so it won't be damaged, remove the turntable from its base and lay it upside-down, being careful to keep the platter engaged so it doesn't fall off, on a thick soft fleece blanket supporting the whole thing by the platter so nothing stresses or interferes with the tonearm. Once again, rotate the tonearm and observe. I'm sure you'll hear or feel where the problem is. The next trick would be to resolve it.
I have an old Dual 1249 that had the same sympton as yours and it was a mechanical binding near the mechanical pivot area beneath the base. One of the links to the auto-eject mechanism was rubbing and you could see the wear on it. The tonearm assembly had come unseated in its cut-out and I just pressed down on it (from its normal top) and it popped back into place, about 1 mm. Voila! Fixed.
Apr 16, 2009 | Technics SL-1210 Turntable
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
Technics SL-1600MK2
Oct 13, 2008 | Technics SL-1200MK2 Turntable
97 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
