I have installed a new wick using the instructions but it goes out when the tank is half full. What could be the problem?
  • 3,382 Answers
It sounds like the wick is to short.
Posted on Dec 11, 2014
How do I replace the wick on a corona 23. I lost my manual
If you've already purchased a new wick from a reputable dealer/retailer and its the one designated for your model Corona heater. The installation instructions come packaged with the wick. I would encourage you to wear rubber gloves if the heater tank still has kerosene in it.
Feb 01, 2011 | Heating & Cooling
Bought kerosene heater in middle of November and seem to have a wick issue. It will not burn properly and makes me wonder if wick was place in upside down. Can I fix it myself?
Trust me you can not install a wick upside down, the bottom of a wick is like an old mop. It has loose wove string and knots, it's job is to **** up fuel. Things to remember about wicks are, they need cleaned some times, I use an old tooth brush and gently brush the wick with it set down low so it does not get damaged. A wick must also sit and soak for at least a half hour before attempting to light it. A good practice to get in to is about every fourth tank of fuel let the heater burn out, this also cleans out the wick and burns off all of the impurities from dirty fuel. Yes you can check your wick but the entire heater does have to be tore down and you should do it only with an empty tank of fuel. This takes time , patience, and a little mechanical know how. When burning out a heater please remove it from your house and let it burn the smell is terrible, if you do this in your house it will smell like a semi truck is running in it.
Dec 28, 2010 | Heating & Cooling
My dynaglo kerosene heater will not continue to burn. It is full of fuel and will light but will not burn. what could be the problem?
Many things can cause this to happen and here are a few of the most common. The wick could be dirty, wicks should be brownish black in color, soft to the touch and flexible. Wicks will get hard and full of soot, my solution is to clean the wick with an old tooth brush gently brush it and I do this with the wick up about half way so I do not damage it. Then I take a shop vac and **** out all the stuff from the wick, make sure it still moves from high to low easily. Now soak the wick for roughly a half an hour and then light it. If the cleaning does not work you will have to change out the wick and remember that soaking the wick is the most important thing to getting good life out of it. Another practice is to burn out your heater each four to five tanks of fuel, this does stink bad so when you do this do it outside. Once you notice that you are about out of fuel take the heater out side and just let it burn out, this does clean the wicks on these heaters. Fill with K1 kerosene soak for the half hour with the wick completely turned down, then set to high and light it up. This cuts down on smell, helps it burn hotter,and in turn burns more efficiently.
Dec 26, 2010 | Heating & Cooling
I have a turco villager 2001 kerosene heater. It has a new wick but won't light
Well things I would do is check the fuel, maybe even go so far as to empty the tank. Next is feel the wick is it hard, is it burnt, a good wick will be a dark brown to black in color. Then it will be some what soft to the touch, if not drop the wick down to what would be a very low setting and I use an old tooth brush to brush the wick and clean it. You only want to make the wick loose do not brush it apart. The fuel of choice is K1 kerosene it burns the cleanest. Fill your heater and let the wick soak with it set as low as it will go for at least a half an hour, now try to light it again.
Dec 14, 2010 | Heating & Cooling
Once I light the wick the flame flutters until it almosts extinguishes itself
Have you ever changed your wick? This sounds as if the wick is dirty or hard to the touch and that is normal on these heaters. First is fuel selection and K1 kerosene is fuel of choice for these. Next as a rule of thumb about every three tanks burn out the heater completely(do not do this in the house it really smells terrible when it burns out). Make sure you soak the wick at least a half hour prior to lighting. If the wick is newer you can try cleaning it with an old tooth brush by raising the wick just high enough to brush it lightly. Feel the wick and if it is hard loosen it up by bending then brushing it. Ultimately you will need to replace the wick and that is all about patience take your time and follow a manufacturers instructions. Good luck.
Dec 13, 2010 | Dyna-Glo Heating & Cooling
Where can I find an Owner's manual for an Everglow Kerosene Heater or in structions on how to install the wick and burner.
First you need to get the shell off the unit, and get down to the main burner area. There should be 4 wing nuts holding the wick tower down to the fuel tank. These must be removed, and the wick and the adjuster apparatus removed up and over the top of the center tower. Having a towel or old rag handy to set the unit on when you get it off is a good idea, so you can work on it. Remove the old wick, taking care to see how the fabric band on the cloth wick is positioned on the bottom edge of the wick carrier band. Install the new wick at the same level as the old one on the carrier and set it aside. Make sure you clean the tower, especially all the black carbon buildup around the center and near the top. I use a wire brush on a cordless drill to buff the stuff off, works great. Remove the old kerosene from the tank and clean the tank best you can, then put the new wick inside the carrier, down on the tower, being careful to get the bottom portion of the wick down into the tank area, (it should be quite loose down there once you get the rest of the carrier on the tower. Make sure the whole apparatus sets down evenly and fairly easily on the bottom tank part and screw it down with the four wing nuts. I use a paper cup to pour clear, K1 kerosene onto the new wick all the way around the tower, then make sure it moves easily up and down with the height adjuster knob and while it's in a down position, pour some more kero in on it. You can pour several cups of kero on the new wick and then when it's working up and down well, turn it up and lite it before you put the whole thing all back together. It's best to do this outside as sometimes you can get smoking, if you don't get the flame spreader cage on quickly enough. Once it's on and the flames come up and look good, then turn it off, let it all cool off and you can put it back together. Remember, don't use anything but absolutely clean, clear, K1 Kerosene in the unit and burn it completely dry at least once a week, if you use it a lot. It's called dry burning, and it's a wick cleaning function. If you do this, the wick can last years and years.
Feb 21, 2010 | Grilling
Dyna Glo model 95 C2 wick replacement is a boogar even with so called instructions is there any trick to this wick is hard to hold in place and insert over round housing without pulling out 3 sidepins have...
turn the wick control knob all the way up before installing new wick. Put it all back together and make sure wick goes all the way down inside the groove when you push the shutoff lever. Do this several times. If not, then heater WILL NOT shut off !! P.S..use clear K-1 kerosene....the K-1 with red color seems to make bad carbon deposits on the wick...in a short time the wick becomes crusted and will not drop down to extinguish the flame. I had to open it up and put baking soda on the wick to put it out.
Dec 16, 2008 | Dyna-Glo RMC-8001SS Heater
Only half of the wicks burns/ flame varies in height/ smokes !
Sounds like you have a wick that has burnt unevenly in the past and now there is not a good setting for an optimum burn. Either the wick needs to be trimmed even or you need a new wick.
Nov 14, 2008 | Heating & Cooling
Wick won't raise.
check with your local hardware ace store like I did my wiks for both my models come ready to install
Oct 27, 2008 | Corona 23-DK Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
