Question about Zanussi Ovens
I have a Zanussi ZTE 285 dryer which runs for 30 seconds and stops, the time to run will go to 0.
I tried to swap the door to open on the other side but stopped when it came to switching over the latch due to internal electrical connection so I replaced the door as was.
    Sergeant:
  • 266 Answers
I'd get a tech in there to fix your door, since that probably messed up the timer internally.
Posted on Dec 12, 2014
huuum
  • 750 Answers
SOURCE: oven door won't open on frigidaire electric range ES200/300
Turn the power off at the breaker box for five minutes.
this will reset the system of any electronic glitches.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Jan 01, 2009
  • 572 Answers
SOURCE: it stopped running, shows door for message. no
there is a fuse that causes this. check it. if door error apears for the micro
Posted on Feb 07, 2010
Testimonial: "thank you I will check"
barkencoa
  • 3463 Answers
SOURCE: zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Posted on Feb 10, 2010
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: replaced control panel on whirlpool electric
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
Posted on Oct 01, 2010
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
How do I fix an oven lock on a self cleaning Kenmore built in dual ovens? The oven locked up during a clean oven cycle and will not unlock.
Some ovens will not open unless the clean button or knob is set to Clean. Make sure you are trying to open in correct direction. Try turning it on and off and press down on the latch while trying to open. I would not use a crow bar, this can be done. If you unplug it and wait for it to reset after about 30 seconds it might let go. Just keep playing mine stuck once and it was because I flipped the clean switch off an turning it back on ready to start the cycle pulled back on it and it opened. Oh I remember my neighbor had a older style dial clock and she set the clock for a certain time to stop and the door would not open until she ran the clock to that time spot. Hope this helps. I wish I knew how to open it from the electrical side but I dont.
Jan 30, 2015 | Kenmore Ovens
My tappen gas range oven locked up and I cannot open the dooI put theoven on to clean, low, it came on and locked up but won't work any more how can I open the door to get my skillits and range top parts...
First, you can try a power-cycle. Unplug or turn off at the circuit breaker for 30-seconds or so. It may reset itself. If not, the lock motor may have stopped functioning and the door will need to be released manually. The lock arm is in the center of the door near the top. Use a piece of stiff wire bent at 90-degrees to give approximately 4 inches that can be slid behind the door at the right side and drawn across toward the left side. With the "crook" hanging down behind the top of the door you should be able to snag the arm. Push gently in on the door while maintaining tension on the wire toward the left. Release the door when you feel the arm move and the door should open.
Apr 09, 2014 | Tappan Ovens
Zanussi oven glass removal
to remove the glass door open the door and you will see two round locks each side of the door with slots just turn the slots with a screw driver and life up the door and pull when putting back push the door back in the 2 slots let it rest in and just pull a little to make sure it in and release the two round locks
Nov 06, 2011 | Zanussi ZHQ575 Electric Double Oven
After running self cleaning cycle cannot open door...
Hi and welcome to FixYa, I am Kelly
The Range has to cool down before the door can be opened due to the safety interlock thermostats. If you just ran the self-clean cycle unplug it (or turn off the Circuit breaker) and let it sit for 2 hours and then try to open the door by pressing the stop/cancel button for more than 3 seconds.
IF this does not work just respond here and I will pass the instructions of how to manually open the door. There will also be troubleshooting required to determine WHY the dook lock is not functioning.
Thanks for choosing FixYa,
Kelly
Mar 15, 2011 | Jenn-Air Ovens
The oven light stopped working so i replaced it but it still does not work although the oven works, I have tried opening and shutting the door a few times but this does not work either
I would first of all try another bulb, if that does not work, then could be a faulty door switch, or bad contacts in bulb holder.
If you can access it, then disconnect the 2 wires going to the door switch and join them together, this will prove if the door switch is faulty, or if there is some other fault.
Dec 28, 2010 | Zanussi ZBF360 Electric Single Oven
Opened oven door seconds after pushing clean. Lock stayed out but by pushing clear and door switch, unlocked but oven will not work, says it is "off" Have turned off power for 5 mins but didn't solve...
the door latch may have over run its normal reach causing it to stick . ck the lever / also try putting it into a clean cycle while holding the latch in the closed position ... i thnk the latch is stuck . you may have to remove it and reinstall . to correct .. power off should have corrected it . so it may be stuck .. mm
Jul 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Feb 14, 2009 | Zanussi ZBF360X Electric Single Oven
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
Ovens Logo
91 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
