Question about Ricoh 3310Le Fax Machine, FAX3310Le Printer
How do you reattach the paper supply sensor?
Nothing
    Champion:
  • Ricoh Expert
  • 208 Answers
Are you asking about the paper empty sensor above the paper tray?
Posted on Dec 14, 2014
  • naveed khan
    naveed khan Jan 10, 2015
    yes , can u help me.
  • paulfvincent Jan 10, 2015
    The little black legs of the sensor clip onto the bottom frame of the machine. If they are broke you need a new one.
Riso com color 7050 error code S41-0198-2 Please Help
This indicates a problem with the front/rigth paper width sensor (Right (front) CIS baseline voltage was not detected correctly at the start of the printing.) Check there is nothing obscuring the sensor ... dirt or a small fragment of paper, for example.
Nov 09, 2017 | Office Equipment & Supplies
How do I reattach a paper pick up roller onto a hp photosmart C5180 all in one printer
In case you are not able to place the paper pick up roller to its slot,call the printer technician to solve the issue. Toll Free No 1-888-224-4280
123 HP COM Setup Printer Quick Setup and Install Support
Jan 28, 2016 | HP Photosmart C5180 All-In-One InkJet...
How to solve transport error on wincor nxdorf 4915xe
usually transport errors mean that something inside the printer is not allowing or not feeding the paper through properly , either a motor isn't kicking on, paper is not being picked up from the supply tray properly or there may be something caught in one of the stop sensors inside the printer that will not allow the paper to pass through properly. unfortunately the only way to fix that usually is to look at every sensor in the paper path and ensure nothing is blocking or holding any of the sensors open if none of those are blocked off then you may have a bad motor on one of the drives that pull the paper from one location to another inside the printer.
Jun 25, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Paper loaded incorrectly.remove paper in HP plotter T610.
T610 with "paper loaded incorrectly" error. Finally removed the paper roll completely and still had error. Opened top, but no signs of paper. I walked behind plotter and on the left , in the paper path ,I found the paper sensor using a flashlight. I got on my back and reached underneath to remove the plastic cover securing the paper sensor and the sensor itself. The sensor was dirty. Blew it off, reattached it and the error disappeared.
Jul 21, 2011 | HP Designjet T610 InkJet Printer
Light goes on but the shredder motor not running when you try to put paper in it. Vacummed it and used water on Q tip to clean sensor still nothing. Only had it for two years
Hi
Well linda in every shredder there is a small sensor flag which trips to make the machine know that the paper has been inserted. Hence there may be some problem in it. Try to check the sensor flag normally black in color and it wiggles when paper is inserted.
NOTE:
DO NOT PERFORM STEPS BY KEEPING SHREDDER ON MAIN SUPPLIES.
Disconnect it first and then try.
Jul 19, 2011 | Staples SPL1506X (CrossCut) Shredder
Paper jam that has been removed and even after re-bbot this error message is being reported.
There are probably little pieces of paper stuck on the sensors, making the printer think the paper is still there. Check in the reels that pull the paper in to make sure nothing in jammed in there where its hard to see.
Mar 08, 2011 | Office Equipment & Supplies
Royal 85X Paper Shredder not working
I have a Royal 10X. Check for a faulty bin interlock.
Feb 01, 2018 | Royal 85X Shredder
Printer won't print
Your Dell unit is really manufactured by Samsung as SCX-4720F/FN. You face one of two possibilities: (1) a paper sensor was moved out of place, inwhich case you need a technician to open the unit and reattach the sensor. Or (2) have you opened the door that located to the back of the unit?
Sep 13, 2007 | Dell 1600n All-In-One Laser Printer
54 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
